Middle selector switch cuts out bridge
Discussion in 'Tele-Technical' started by Gratusin, Sep 18, 2019.
  1. Gratusin
    Gratusin TDPRI Member
    Durango, CO
    Hey guys, first time caller long time.... I just finished a DIY Tele Deluxe kit, damn thing is gorgeous, buuuuut it ain’t perfect. When the switch is on neck only, neck pickup works, when it’s on bridge only, bridge works, but when it’s in the middle only the neck pickup is on. I opened it back up for about the hundredth time and rechecked my schematics (I put push pulls on both volumes for coil split) and wiring looks fine. The only thing I found online was for an SG and they said check the spring on the switch, but as far as I know this cheapo switch doesn’t have one. Any hints?
  2. jimilee
    jimilee Tele-Afflicted Silver Supporter
    Chattanooga
    Without seeing the wiring, we would only be guessing.
    From where can I purchase the same kit?
  3. Gratusin
    Durango, CO
    Oh gah, pull it apart again haha. I’ll post a pick this weekend. Wanna use it for practice tomorrow. My wife got the kit from the fret wire for my birthday. I added Duncan pickups and push pull pots.
    Mincer likes this.
  4. POS Guitars
    POS Guitars Tele-Meister
    Los Angeles
    You might have a number of issues. The easiest to overlook is either your contact touching ground when buttoned up, or a physical switch damage.
    LowCaster likes this.
  5. jimilee
    Chattanooga
    That looks pretty awesome. Which Duncan diagram did you use?
  6. Gratusin
    Durango, CO
  7. Gratusin
    Durango, CO
    That link didn’t work correctly. Of course, just my luck with wiring diagrams! It just the two volume (two coil split), two tone, 3 way toggle diagram
  8. Gratusin
    Durango, CO
    After checking the schematics, I’m thinking it might be the switch. If there was contact with the shielding somewhere in the chain (I shielded everything with copper tape) then wouldn’t that ground out the pickups? Like I said, both pickups work in their respective positions, but just not together.
  9. Wally
    You have a wiring problem at the selector switch, I would guess. Note: acceptance of the ‘correctness’ of one’s work when reviewing for problems is a trap that will prevent one from seeing the problem......time after time, even.
    You don’t show us a diagram of the selector switch, and pics of the work might be helpful.
    Gratusin likes this.
  10. LowCaster
    LowCaster Tele-Afflicted
    Paris, France
    First I would use an ohmmeter to test the switch. That’s easier than to review the whole wiring, and easy to fix (replace).
    I once had a similar problem, and the switch was OK but the problem was caused by one contact lug of the switch making contact with the shielding of the cavity. Problem solved with some adjustments and a piece of tape stuck on the shielding.
    Gratusin and Wally like this.
  11. Gratusin
    Durango, CO
    Popped off the neck and pickguard and heat shrinked everything that had a single connection point. Put er back together and same issue. Bridge works, neck works, but only neck again in middle position. I wasn’t really sure what to be looking for regarding the ohmmeter, I tested each side with the black in the middle, red on respective side, then in all positions on the toggle and was getting pretty much same resistance regardless of position. I’m obviously no electrician. Just ordered a switchcraft toggle to hopefully fix this thing. Thanks for all the replies guys!
    . IMG_3324.JPG schematic I’m using
    toggle switch
  12. jimilee
    Chattanooga
    That’s a switchcraft? Don’t look like any switchcraft I’ve ever seen. BUT did it come with a pin out diagram?
  13. Wally
    Yah, that Switch is not something that I would bother with wiring up unless I was in dire straits. That said, if I had that switch in my hands, I believe I believe I could take it apart and make it work when I put it back together. The new switch will fix the problem.
  14. Gratusin
    Durango, CO
    The one in the picture is definitely no switchcraft. It’s basically the only thing other than the neck and body that I kept from the kit. New toggle will be here on Monday unfortunately. Got a gig next Friday, so hopefully I’ll have the thing up and running by then.
    Wally likes this.
  15. jimilee
    Chattanooga
    Oh yeah. A proper switch will fix it as fast you can solder it.
  16. Gratusin
    Durango, CO
    New switch installed and it works! Much smoother, but I sprayed a bit of de-oxit in it just to be on the safe side. The switchcraft toggle was much wider, so I made sure to heat shrink all the connections and put some electrical tape in the cavity to make sure it doesn’t ground out somewhere. Both pickups now work on the middle position. Thanks for your help guys! IMG_3340.JPG
    Wally and LowCaster like this.
