Mexican truss rod nut
Discussion in 'Tele-Technical' started by anthony, Mar 4, 2021.
  1. anthony
    anthony TDPRI Member
    Hi, hope soemone can assist me.
    I have bought a used Player series tele, and now find that the truss rod hex nut is stripped.
    I believe that these can be replaced, by removing the plastic dowel insert and usin some type of extractor tool to unscrew them from the hole.
    The questions I have are ;
    1, How to remove the plastic dowel from the truss rod hole.
    2, I presume that getting the dowel out , will mean replacing it with a new one .
    Would anyone know whether I can buy these anywhere in the uk?
    3 I know that with the USA models the wooden dowel acts as a stop which the truss rod adjusts against to flex.
    Is this the same for the plasyic one ?
    Thanks for your help
    Fendereedo likes this.
  2. Fendereedo
    Fendereedo Poster Extraordinaire
    Potato
  3. JamesAM
    JamesAM Tele-Meister
    Virginia, USA
    Best of luck- this is a tough one. Fender spec says to use a hair dryer, not a heat gun, and to tape aluminum foil around the headstock to prevent damage. Heat the plastic sleeve until the glue melts, then unscrew the nut to back out the sleeve or use a paper clip or other tool to pull the sleeve out. You can use a drill out to remove the nut itself. Same procedure as the American standard with the walnut plug.
    I live in the nova/dc area and couldn’t find a single tech who could confidently do this for my am std. Best response I got was from a large chain who shall remain nameless who literally told me “sure, we’ll give it a shot.” Even a local guy who was fender certified said he’d never done one before. Don’t mean to be a Debbie downer, just wanted to share my sample size of 1.
  4. anthony
    Thanks Fendereedo, I had watched this video, but it shows a wooden dowel being removed.
    I was just wondering if there was some other method for the plastic one- as heating it with a solder gun would melt it?
  5. Fendereedo
    Potato
    Hi Anthony, it is a tough call mate to be honest. It's the only vid I could find though. That Stew Mac kit is pretty good. They have a lot of demo stuff on YT as well, which might be helpful. Good luck though buddy with the removal of the nut.
  6. Fendereedo
    Potato
    Just curious @anthony, is there a tech near you. I used to live near Doncaster, and there was a chap who used to fix John Squires guitar, used to work out of Electromusic, sadly they're gone, but I can look the guy up if your in the Yorkshire area.
    stepvan likes this.
  7. stepvan
    stepvan Tele-Afflicted Silver Supporter
    out there somewhere
    Was anyone able to sort out WHY the truss rod was stripped at the hex? You may be able to get a long pattern Allen wrench and tap it in to get it to catch, the hex nuts are pretty deep and usually strip at the top 1/3 maybe or if the wrong wrench was used just a thought.
  8. T00DEEPBLUE
    T00DEEPBLUE TDPRI Member
    A common reason for stripping hex nuts in MiM Fenders is their irritating use of Metric and Imperial parts on the same guitar. Coupled with the fact that a 4mm metric Allen wrench is slightly undersized to fit a 3/16" hex but will indeed turn it. However put too much torque through the 3/16" hex and a 4mm key will strip it.
    If you somehow needed even more proof that the imperial system is an engineering blunder, there you go.
    anthony, Fendereedo and stepvan like this.
  9. stepvan
    out there somewhere
    Yeah I can't argue with good logic!
  10. anthony
    Thanks Fendereedo, but I am in Swansea. - There are some guitar techs close to me , but ideally I would like to try to repair this myself
  11. anthony
    Hi ,
    I have managed to get a flat headed screwdriver into the truss rod hole , and am able to turn the nut. I have adjusted the relief ok.
    I will still want to replace the nut though, looks like I will need to heat the plastic dowel to remove it - using JamesAM advice.
    So i am still wondering as to whether I can buy a new plastic dowel- or do I need to replace the dowel at all?
  12. Fendereedo
    Potato
    No probs mate, best of luck to you.
  13. Fendereedo
    Potato
    I think Fender sell blanks, but you may need to cut them. It's a long time since I saw them though.
    stepvan likes this.
  14. The Ballzz
    The Ballzz Tele-Afflicted
    Las Vegas, NV
    Someone please correct me if I'm wrong, but given that your truss rod is NOT a two-way/bi-flex, the plug is purely cosmetic. You could leave it off, unless it bothered you visually?
    It's my considered opinion that those plugs (both plastic and wood) may be one of the actual causes of stripped truss rod nuts. If they don't line up well with the angle/center line of the hex, it can prevent you from getting the allen wrench fully engaged and then........! I think it's a pretty pi$$-poor design! I think the older "bullet" design was a better way to do it, although it does not facilitate the "bi-flex" system. But for that matter, I've not seen many necks that truly require the opposite function of the "bi-flex" rod. This would lead me to believe that even on a MIA, as long as the neck doesn't require that reverse action function, the plug could be left out and the neck fitted with a bullet style nut, even as clunky and ugly as many may think it to be! Or just leave the plug out, for more precise access to the existing nut/hex.
    Just My "Nutty" Thoughts!
    Gene
    JamesAM likes this.
  15. anthony
    Thanks Gene,
    That is what I was wondering myself- the option of leaving the dowel out!
    But, I have had some luck, in that whatever I did with the flat headed screwdriver which let me turn the nut, has let me now insert the 3/16" allen key and turn with that?
    Happy days..
    Fendereedo and JamesAM like this.
  16. Tuxedo Poly
    Tuxedo Poly Friend of Leo's
    Merseyside UK
    There is absolutely no reason to remove the plastic truss rod insert on a MiM neck. The nut simply unscrews out.
    The Fender replacement part number is 0038454000
    LutherBurger and JamesAM like this.
  17. anthony
    Thank you - thats good news Tuxedo Poly!
  18. Blockhart329
    Blockhart329 TDPRI Member
    Tampa
    My dilemma is a broken truss rod. I removed it, but cannot find another just like it. I will most likely end up making a new one for my 21 Yr old Squiet Strat neck.
