Metal Amp Corners for Bottom of DRRI Cabinet.
Discussion in 'Amp Central Station' started by alnico357, Mar 23, 2021.
  1. alnico357
    alnico357 Tele-Afflicted
    Arkansas
    I am not finding any amp corners that specifically state they will fit the bottom of the DRRI cabinet. Any info to share? Thanks!
  2. Ringo
    Ringo Poster Extraordinaire
    Memphis TN
    The 2 screw corners with a lip as used on the bigger Fender amps will work, I've used them on a Deluxe Reverb.
    Originally the DR amps didn't come with amp corners.
  3. alnico357
    Arkansas
    I see that the rubber feet would need to be re-positioned. I replaced the metal glides with rubber feet on my amp.
  4. uriah1
    Around
    Seems like they would fit most..with a hammer.
  5. SoK66
    SoK66 Tele-Afflicted
    Four Corners USA
    Fender used to sell these as an accessory. Not as easy to install as they might seem, particularly with the baffle installed. Squaring them up and seating with a plastic hammer worked for me on a PR cabinet. Very common for the corners to get frayed on vintage and reissue DRs.
  6. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    I use the two-hole type with the flat front. The screw for the rubber foot goes through the hole in the bottom of the metal corner:
    You can use the type with the hook that rolls over the corner on the front, but those will not work on the back because rear panel is flush with the edge of the cabinet. This type:
  7. alnico357
    Arkansas
  8. Willie Johnson
    Willie Johnson Tele-Afflicted
    Chicagoland
    My local shop sells these--Fender original parts. I put some from a 90's solid state Ulta Chorus onto a blonde Super Champ X2 and it looked class--sturdier and high up enough to clear the handle when stacked on top of another Fender combo amp.
  9. Bob Arbogast
    Bob Arbogast Tele-Afflicted Silver Supporter
    Lowell, Michigan USA
    Funny . . . my DR clone has no corner protectors, like the originals. And the cabinet I have coming for my new Allen Amps Sweet Spot also will have no corner protectors, at my request. I like the bare look better. And I have no problem if my amps show wear and tear--as long as they are functionally solid.
    Different strokes . . .
  10. Peegoo
    The originals from the 60s didn't come from the factory with corner protectors. They were add-ons, and players that dragged their amps around quickly saw the utility of slapping 'em on. Some players also added them to the top rear of their amps, because if they had no tilt-back legs installed, they would lean their amp at an angle against a wall or other solid item. It prevented the top corners from wearing through the Tolex.
