Mesa tubes - typical life span?
Discussion in 'Glowing Bottle Tube Amp Forum' started by Southpole, Jan 23, 2020.
  1. Southpole
    Southpole Tele-Holic
    WellingtonNZ
    Not sure if this is just me, but I seem to wear through Mesa branded tubes more quickly than in the past. I use 6L6GCs and EL84s in Mesa amps. Anyone else had this experience? What are the best alternatives for Mesa amps?
  2. Dacious
    Dacious Poster Extraordinaire
    Godzone
    JJs for EL84s but that's what Mesa tubes are. You should get a year minimum regular gigs and rehearsal
  3. Southpole
    WellingtonNZ
    Definitely not getting a year minimum. Five / ten years ago probably yes. Might have to experiment with non Mesa brands to see if it’s any different.
  4. Dacious
    Godzone
    Maybe it's worth checking your bias circuit resistors. They may have drifted causing higher current draw.
    JayFreddy and Milspec like this.
  5. Nick Fanis
    Athens-GREECE
    There's no such thing as a "MESA tube".
    They are rebranded tubes by various manufacturers ( in most cases Svetlana, JJ,SOVTEK or Shuguang )
    This.
    BobbyZ, slider313 and uriah1 like this.
  6. That Cal Webway
    That Cal Webway Tele-Meister Silver Supporter
    Minot
    Mesa screen their tubes thoroughly
  7. Wally
    are these tubes going into Mesa amps? plus one on knowing bias numbers...especially if tube wear is excessive.
  8. Rowdyman
    Rowdyman Tele-Meister
    Eastern Canada
    Mesa tubes are screened and 'matched'.
    I used to just call them in CA and they would send them directly to me for about $10.00 per.
    A number of years ago they stopped sending them directly, and simultaneously started to sell them through a local music-store chain. (Long&Mcquade)
    The price jumped ~ 300% at that time.....
    It's over 60 bucks for a pair of EL84s now. Scandalous!
    And you are right,, they don't last long,,,,,, RM
    Southpole likes this.
  9. Milspec
    Milspec Friend of Leo's Silver Supporter
    Nebraska
    The only Mesa branded tubes I've had were in a '67 Gibson GA-5T which was a dedicated daily practice amp for a couple of years. I installed those tubes and 3 years later sold the amp....same tubes. No gigs with it, but played 2 hours a day nearly every day with it.
    I would seriously check your bias to see if they are running too high.
  10. Southpole
    WellingtonNZ
    Thanks all. Checking bias circuit resistors is a bit out of my league. Might be time to talk to an amp tech!
  11. trxx
    trxx Tele-Holic
    Between reality and imagination
    An amp tech recently told me that older Mesa tubes were a good quality / performance value that he recommended as standard replacements and that newer Mesa tubes, not so much. I'm not sure what changed over the years. Probably who manufactured the old Mesa branded tubes vs. the various manufacturers of today. Maybe someone here knows something about that. Any way, he also told me that he generally recommends JJ as standard replacement tubes these days.
    scooteraz and Southpole like this.
  12. bftfender
    bftfender Friend of Leo's
    York PA
    mine are doing very well in the lil monster....got it this way....liked it so much..left em in...amp is never off the dimed setting..just the right volume for everything 3203e.jpg
  13. slider313
    slider313 Tele-Afflicted
    NC
    Mesa tubes, like other "tube distributors" are made by one of the three factories still making tubes today. JJ (Slovak Republic), New Sensor/Reflector Corp (Saratov Russia), Shuguang (China). Some folks believe Mesa, Groove Tube, TAD, Ruby, etc. have tubes made to their specifications but, AFAIK, these companies just test and screen the tubes for shorts and imperfections; then match them up into pairs. What you're paying extra for is their time and warranty.
    Frodebro and Chiogtr4x like this.
  14. WireLine
    WireLine Tele-Afflicted
    Midland TX
    Ive always had great and long lasting results with Mesa STR 6L6s. Put em in a Bandmaster Reverb some while back, and they are still beasts
  15. slider313
    NC
    Back in the 1970's and early 1980's the Mesa 6L6GC STR was simply a Philips 6L6GC-STR that Mesa would test and sort into matched pairs. They were one of the best 6L6GC tube types ever made. I believe the STR 387 was the standard single getter GC where the STR 415 was actually a dual getter 7581A.
    BobbyZ and WireLine like this.
  16. Southpole
    WellingtonNZ
    Seem to recall that there are a variety of STR numbers for 6L6GCs.
    Starting to wonder if it is a bit like ink cartridges for printers, over time you pay more for the cartridges than the printer.
    I’m not a pro or even semi pro so my amps have an easy life. But somehow I’ve managed to wear through a pair of EL84s in about 4 months. Previously they would last much much longer. Either this amp is dodgy or tube quality has declined.
    I like to have spares on hand so some time may pass between buying spares and using them, so I can’t make use of the guarantee. Will buy some new ones today.
  17. Lakeabilene
    Lakeabilene TDPRI Member
    East Coast
    If you can't tell the difference, by all means just put some cheap JJ's in there, they will probably last forever because you will play some other amp that sounds better because it doesn't have JJ's.
    tubedood and snottyboy like this.
  18. zombiwoof
    zombiwoof Tele-Afflicted
    Tujunga California
    Some people "believe" that GT and TAD have tubes made to their specs because they do have SOME tubes made by Shuguang to their proprietary specs. Yes, the rest of the tubes they sell are just stock current manufacture tubes that they test and rate using their system.
    Al
  19. slider313
    NC
    Do you know which tube designs are proprietary to GT or TAD? Do you have any photos as I would like see the physical difference between the stock Shuguang 6L6 and its TAD counterpart.
  20. BobbyZ
    BobbyZ Doctor of Teleocity
    Snellman MN
    The only Mesa or Groove Tubes tubes I'd buy would be the old ones from when they were still relabling US and western European tubes. That ended years ago and the chances of finding those still new in the box are pretty slim. Maybe in some backwater mom and pop place, like there's a lot of those left!
    Today just buy from a good vender that tests the tubes, stands behind them and doesn't try to sell hog wash and crap in fancy boxes.
    Most of them can sell you tubes that'll work in with Mesa's fixed bias set up.
    Oh wait, do I mean there's no magic in Mesa's bias system? Yes there's no magic in that system.
    The magic is in the marketing. :)
    Absolutely a brilliant move from a marketing prospective.
    Southpole and slider313 like this.
