Axean naexA
Mesa/Boogie TA-15 TransAtlantic - Tone Evaluation - PART 1
GETTING TO KNOW THE BEAST
I tried searching the internet for any meaningful info regarding my Mesa Boogie TA-15 TransAtlantic guitar amplifier, but after relatively fruitless results (other than brief reviews revealing nothing specific) I decided to take matters into my own hands and even came up with a couple simple, yet profound "enhancements" along the way.
In fact these so-called enhancements are so stupidly simple that I'd just wanted to make sure it's understand that my goal here is to do more than just pass on a couple of quick fixes, but also briefly describe the TA-15's various attributes as well as point out whatever pros or cons that may apply to it. I did this for the benefit of anyone looking to better understand their amp or are perhaps considering getting one, so please forgive my fairly long-winded tirade...
First a little background info:
As of the year 2015, I have been playing guitars, working on guitars and even sleeping with guitars (not that way sicko!) for about 35 years. I enjoy live performance as well as recording and can attest to how difficult it can be to get a great sound and how rewarding it is when you do.
My main guitars currently include a 1988 PRS Custom 24, a 1991 Gibson Les Paul Studio, a 2003 Fender AVRI '52 Telecaster and a 2012 Fender American Standard Stratocaster.
I plug my TA-15 into a Mesa Boogie "wide panel" speaker cabinet with a 3/4 closed back design. Inside is a special - made for Mesa Boogie - Celestion MC-90 "Black Shadow" 8 ohm, 90 watt speaker.
Before I continue I'd like to give you my first helpful tip pertaining to the TA-15's sound - actually it's more of an observation than a tip - and that is to let the amp sufficiently warm up before expecting optimal tone from it.
More often than not, when I first turn the amp on, it doesn't seem to sound quite as good as the last time I played it and of course I'd start fiddling with knobs - only to find that after about 15 to 20 minutes it would sound great. It could be my imagination, but I've also noticed a similar short delay after coming off "Standby", no matter how long the amp has been on. Any amp experts or physics majors are welcome to chime in, otherwise it's just something to consider.
Anyway...
Overall the TA-15 has full, rich, well balanced sound with a wide variety of tonal possibilities, from crystal clear to blues, classic rock and heavy metal, so not surprisingly I was interested in getting at least two main types of sounds out of this amp: "clean & dirty".
I won't go on and on about the high gain overdrive/distortion parts of this amp, except to say that I feel Mesa Boogie has done an excellent job getting as much as you could reasonably expect considering its size and stature, and, with a little help, I'm sure most people will be thoroughly happy with what it's got (more on this in a bit).
I did initially have some trouble getting the cleaner sounds to come out the way I wanted but happily it didn't have anything to do with the amp itself and I managed to find an easy solution to that dilemma as well.
Something else to mull over if you are seriously considering getting one of these amps is the perceived output. Although there is a remarkable amount of volume available from this little firecracker, there's still reason to be concerned if you plan to use it in live performance situations.
The higher gain settings can certainly push some air and may potentially be able to handle a decent size club. The cleaner sounds are also capable of cutting through in most modest sized gigs, but, at only 25 watts, it's no surprise that clean headroom starts to diminish fairly quickly after a certain level.
My point is this: If clean "live" playing is your main goal, then you may need to think about getting something with a little more power in order to make sure you have the necessary leeway needed to actually pull it off. Also, clean or dirty, as you crank up the gain the amp eventually starts to lose some lower end tightness.
So basically the TA-15 is designed for medium to small sized venues (unless you can mic it) or for recording purposes. Either way I can pretty much guarantee that you don't want to be standing in between the guy with a 100 watt Stack and the crazy drummer with a heavy hand! You WILL be pummeled mercilessly into the ground :,(
Now on to my arguably ingenious improvements...
First I'll address the overdrive/distortion sounds.
Soon after getting my new TA-15 in 2010 I began to realize that, if left to its own devices, it would be no "Recto-Monster" - at least not without a little help. I just don't think those little EL84 tubes have enough "oomph" to push the amp into the super-saturation zone by themselves. Some people may disagree with me but, from my experience with other Mesa Boogies, I knew there should be more.
Fortunately I came up with a brilliant solution: Push the front end of the amp with a booster pedal!
OK, I can't really take credit for this idea since it has been a trick used by many players to get a little more juice out of their amps, but whatever works, right? And does it ever!
I personally use an Xotic EP Booster to turn up the heat, and it does it in spades! I love this pedal for the way it adds some extra dimension to my sound without actually coloring it. In fact, sometimes I just leave it on (set at the lowest level) to add a little magic to everything.
Now when I need that over-the-top, delicious, harmonically rich sustain all I have to do is kick in the booster and I'm in crunchy, wailing, tube clipping heaven! The amount of gain available now is enough to melt your face and definitely enough to please even the most ardent distortion freak.
Even cleaner tones can benefit with the booster trick too. I couldn't really get the punchy tone I wanted out of my Strat's bridge pickup, then I kicked in the booster and it went into blues overdrive heaven!
Anyway, as far as the TA's overdrive/distortion goes... Problem solved!
Now for the cleaner side of this amp:
For clean single note solos, double stop riffing and vast arpeggiated soundscapes, the TA-15 is a real joy to use. This is how I play (clean-wise) most of the time and I am extremely satisfied with how the TA-15 performs.
However, I ran into trouble when full chordal bashing was required and, yes, I do realize some finesse is required here. The problem mainly involved chords (especially open chords) and anything played on the more trebly side of the fretboard. In that case the sound could go from a nice chimey, bell-like delight to an ear-splitting, ice-picky treble hell in an instant! Plus there was this mid-rangy murkiness that seemed to drown out certain notes, blurring the overall sound.
Backing off the volume/tone controls on the amp and/or guitar only made things sound weak, muddy and drab. EQ's and other external processors also failed to deliver. The only conclusion I could come up with is that it had something to do with the speaker or the amp voicing itself.
I couldn't have been more wrong!
Before I go any further, I'll just cut to the chase and give you the moral to this story: If you aren't entirely happy with the sounds you are getting from your setup (assuming you are using high quality stuff), try replacing the guitar cable first!
At any rate, here's the wrong way to approach the problem:
My first impulse was to try different speakers. At the very least this is a "hit or miss" approach. At the very worst it can be very expensive. Well, after spending a great deal of time (and some money) trying out several speakers I wound up staying with the same MC-90 speaker that I started out with. Luckily I already had most of the other speakers on hand. I suppose at least one good thing that came out of this endeavor is that I now have a a much greater appreciation for the quality of the original speaker.
My next venture was to try changing out the preamp tubes. I have various 12AX7, 12AT7 and even a couple 5751's laying around, so after a lot of serious tube swapping - guess what? - I ended up keeping the original Mesa 12AX7's that came with the TA-15!
I was starting to get quite frustrated by now and even contemplated looking for a different amp when I decided to try one more thing... testing different guitar cables!
I had read where this can significantly affect your tone but never quite gave it the consideration it so rightfully deserved - until now! Duh! Well, I am here to testify that it is all true. After doing a little research I decided to go with a cable from armorgoldcable.com and was quite literally blown away! Note that there are a lot of good cable companies out there so please don't limit yourself to my choice, however, keep in mind that spending more money doesn't necessarily guarantee you'll get a better sounding guitar cable either. Caveat Emptor.
So, with this one simple change (see I told you it was easy) suddenly everything fell into place. The piercing highs were gone as well as the mid-range muck. Chords are now clear and warm, while still being sparkly and bright. It's like I put the perfect EQ between my guitar and amp.
I know, you probably feel gypped by my totally lame solutions, but the good news is that the TA-15 is a well designed, awesome amp right?
Anyway, who'd of guessed that such ridiculously easy results saved me from total financial ruin! Ok, no so much. I only mention all this so that other's may avoid my folly.
CONTINUED IN PART 2...
Anyway...
