For Sale/Trade Mesa Boogie Mark Five 25 - Custom Vintage Bordeaux Taurus Covering W/Wicker Grill - Authorized Dealer - Trades?
Morgan Music
Vendor Member
Lebanon, Missouri
Brand new Mesa Boogie Mark Five 25 - Custom ordered Vintage Bordeaux Taurus Tolex W/ wicker grill - Selectable output...either 10 watts or 25 watts - 10" Celestion Cream back speaker (see photo) - Built-in CabClone for going directly into a recording or live console...no more direct boxes!
The total weight is only 24 lbs! More Mesa Boogie magic in an all tube amp made in the USA!
CHECK OUT THE VIDEOS BELOW!
$2388.00 shipped and PayPal'd - CONUS sales only please.
TRADES ALWAYS CONSIDERED - we are always looking for used electric and acoustic guitars, amps, and especially used effects pedals of any kind.
Questions? Please send us a note and we will get back to you as soon as possible.
Full specs from the Mesa Boogie web site:
The Best of Mesa's Preamp Technology
Sporting two fully independent channels with six style modes, the Mesa/Boogie Mark Five: 25 tube combo gives you legendary Mark Series preamp tone combined with Mesa's proprietary Dyna-Watt 2 x EL84 output section. This Mark Series amp gives you maximum portability and responsiveness. Dial in everything from sweet cleans to roaring leads with extra midrange crunch and aggression when you push the EL84 power tubes hard. Harness the warmth and distinctive growl that epitomizes British guitar tone, thanks to a Celestion Custom G10 Creamback speaker. Factor in the built-in Cabclone speaker-emulated direct output, and you have an amazing gigging and recording amp with the Mesa/Boogie Mark Five: 25 tube amplifier.
Channel one takes you from clean to crunch
The Mark Five: 25's first channel is a rhythm player's sonic playground with clean, fat, and crunch modes serving up an amazingly wide range of tone. Use the Multi-Watt power switch to flip between 10-watt mode for more breakup at lower volumes or 25-watt mode for more headroom and a different playing response. The powerful mid-boost control is all you need to push your tone to the front of any mix.
Channel two brings you legendary Mesa lead tone
Three switchable styles give the Mark Five: 25 everything you need for epic lead tones. Choose from Mark IIC+, Mark IV, and Xtreme modes for three distinct flavors of sonic aggression with switchable 10-watt/25-watt operation for adjustable response and power amp breakup. From smooth and liquid to roaring and edgy, the Mark Five: 25's lead channel gives you more sonic flexibility than most 2-channel amps provide in total.
Built-in Cabclone — achieve awesome tone without a speaker
The Mark Five: 25 packs an indispensable tool for gigging guitarists and an outstanding studio tool, too: a built-in Cabclone internal amp load and speaker simulator. It provides an incredibly realistic speaker-emulated direct output to plug right into the sound system or recording chain.
Mesa/Boogie Mark Five:25 Combo Features:
  • 2-channel, 1x10” 10W/25W tube combo amplifier
  • Gives you the same legendary preamp tone as Mesa's Mark V, Mark IV, and Mark IIC+ preamplifiers
  • 2 channels with 6 total style modes give you an amazingly wide range of tone to explore
  • Custom G10 Creamback speaker exhibits warmth and a distinctive growl
  • Built-in Cabclone speaker simulator and internal load box give you awesome direct tone
  • Ultra-rugged design with all-aluminum chassis
  • All-tube spring reverb can be applied to each channel independently
  • 2-button footswitch (channel 1, channel 2, and EQ) and slipcover included
Tech Specs
  • Type: Tube
  • Number of Channels: 2
  • Total Power: 25W Class AB (10W triode setting)
  • Speaker Size: 1 x 10" Celestion G10 Creamback Speaker
  • Preamp Tubes: 6 x 12AX7
  • Power Tubes: 2 x EL84
  • Reverb: Tube-driven Spring Reverb
  • EQ: 5-band Graphic, Treble, Mid, Bass
  • Inputs: 1 x 1/4" (instrument)
  • Outputs: 1 x 1/4" (internal 8 ohm), 2 x 1/4" (4 ohm parallel), 1 x XLR (CabClone DI out)
  • Effects Loop: Yes
  • Headphones: 1 x 1/4"
  • Footswitch I/O: 1 x 1/4" (channel, EQ)
  • Footswitch Included: Yes, 2-button footswitch
  • Construction Material: Black Taurus Vinyl with Black Jute Grille
  • Power Source: Standard IEC AC cable
  • Height: 14.75"
  • Width: 14.12"
  • Depth: 9.37"
  • Weight: 24 lbs.
