Melting solder on the chassis. What are my options?
Discussion in 'Amp Tech Center' started by Greg M, Aug 14, 2018.
  1. Greg M
    Greg M Tele-Holic
    Virginia
    I've got an adjustable solder station to do the component soldering, but the can cap legs soldered to the chassis are giving me trouble. My iron just won't melt the stuff. So what are my options here? How high does the wattage need to be on an iron, and is there any other way of doing it? If it wasn't so close to other components, a torch would work. I really don't want to spend a lot of money on an iron that I may only use once, as I usually just work on pedals and guitar wiring. Any advice is appreciated.
  2. Outcaster
    Outcaster Tele-Holic
    The Mountains of Western North Carolina
    BobbyZ and D'tar like this.
  3. D'tar
    D'tar Friend of Leo's
    WNY
    corliss1 likes this.
  4. JohnS
    JohnS Friend of Leo's
    Sparks, NV
    I use a 100 watt iron I got for doing stained glass. Works great.
  5. Greg M
    Greg M Tele-Holic
    Virginia
    $25 for a 200w iron ain't bad. I'll probably have to go with that. I wish my electric charcoal starter would fit in there :)
  6. clintj
    clintj Friend of Leo's
    Idaho
    85W and the fattest, chunkiest chisel tip the iron can take will get the job done. Those stained glass irons sure are nice for that work, though.
  7. Wally
    I gave up buying new ‘big irons’ and find mine amp garage/estate sales......good old American products that just keep on working. $1-2 per iron....bargain time.
    BobbyZ, schmee and Bill Moore like this.
  8. Bill Moore
    Bill Moore Tele-Afflicted Silver Supporter
    Silver City, New Mexico
    Another thing to be aware of is to brush some flux on the area you plan to solder to. (Rosen is a mild acid that etches the metal for the solder to adhere to). Some folks also sand the area.
  9. PCollen
    PCollen Friend of Leo's Silver Supporter
    Man of the World
    Can you solder a wire to the can cap leg, attach a lug to the other end, drill a hole in the chassis and secure it with hardware ?
    Tonetele and bblumentritt like this.
  10. jtcnj
    jtcnj Tele-Holic
    Brick, N.J. USA
    D'tar likes this.
  11. Phrygian77
    Crawfordville, FL
  12. bblumentritt
    bblumentritt Tele-Afflicted Platinum Supporter
    Austin, Texas
    That's what I do.
  13. Greg M
    Greg M Tele-Holic
    Virginia
    Pretty sure I would screw that up pretty bad.
  14. PCollen
    Man of the World
    It would allow you to form a star-ground point for those chassis-grounded cap can legs.
  15. pdmartin
    pdmartin Tele-Meister
    Chillicothe- the armpit of Ohio
    On radios I’ve built I drilled several small holes in a circle around the area I wanted to solder to. The idea is to maintain the ground connection but reduce the heat sinking effect of the chassis mass.
  16. mgreene
    mgreene Tele-Afflicted
    south carolina
  17. schmee
    I have Weller 75 watt ones that work fine on the chassis. Also have a big 150 watt one, but it's not needed at all. Yard sales or second hand stores is where I got two 75 watt and one 150 watt. Nothing over $5. Also, look at pawn shops and second hand stores. Also a little bit of electronic soldering flux is great for large soldering or removing very old stuff.
    Like this: $32 new: https://www.frys.com/product/283468...gtnt2Lb9esyYRKJA2HbC4VHhyUorkgphoCe3QQAvD_BwE
    LarryBudMelman likes this.
  18. 3-Chord-Genius
    Winchester, VA
    You do NOT need a hotter iron, just a wider iron tip. I use a little 40W iron, but with a wide tip, and have no problem melting solder on the pot chassis.
    jvin248 likes this.
  19. jimgchord
    jimgchord Tele-Afflicted
    victor,ny
    Lug, bolt,nut
  20. jimgchord
    victor,ny
    I think he's referring to an amp chassis, not a pot
    PCollen likes this.
