Melody Maker build
Discussion in 'Tele Home Depot' started by flatfive, Oct 14, 2011.
  1. emoney
    emoney Tele-Afflicted
    Hudson Beach, Florida
    Hey, I'm glad I got caught up on this build. carry on please.
  2. flatfive
    flatfive Friend of Leo's
    Monterey, CA
    Hey there, Dave. Thanks for sharing that -- I'll have to
    check out some of those classic books. But isn't reading
    20 or 30 comments, scattered around the web and
    providing contradictory opinions, easier that reading the
    well-organized thoughts of one experienced luthier? :lol:
    Good to see you around, and to see you also survived the
    challenge.
  3. flatfive
    Monterey, CA
    I've been making a little progress. I thinned the neck
    down a lot, then redid the transitions.
    Before going any further I wiped naptha on the neck
    to check for problems. I was amazed at the size of
    some the scratches that were invisible before I
    used the naptha.
    Sorted them out, then wiped shellac on the neck
    to keep dust and dirt out of the wood -- and also
    because it's just fun to wipe shellac on stuff.
    Then I figured that there should be a mother-of-pearl logo
    on the headstock.
    The face of the headstock will be painted black. I figure I'll
    scrape the black lacquer off the inlay, as I understand they
    used to do at Gibson.
    Pattern glued to MOP with gel super glue.
    Started the sawing:
    If this turns out nicely I may use it as a pattern for
    a dremel-based pin router I'm going to make. More on
    that soon, I hope.
  4. flatfive
    Monterey, CA
    Here's the setup for sawing the mother-of-pearl:
    The sawed pieces:
    I'm slowly sawing better, but I'm still sawing slowly.
    Tomorrow I'll clean the pieces up with files.
  5. emoney
    Oooohhhhh, a "Dremel-based pin router"....now I'm really excited!!!
  6. GerryB
    GerryB TDPRI Member
    Somerset, NJ
    What a great job you're doing with this guitar (and I'm not a MM fan).....you're making me want one now.
  7. flatfive
    Monterey, CA
    It's very simple. Hope I can put it together and try it this
    weekend.
  8. Greg M
    Greg M Tele-Holic
    Virginia
    This is great! Looking forward to the sunburst work.
  9. sjohnbruton
    sjohnbruton Tele-Holic
    Mobile, AL
    I'm betting "simple" is a relative term here. I hope you can put it together and try it this weekend, too! I wanna see plans! :lol:
    Great looking build, btw. ;)
  10. flatfive
    Monterey, CA
    I started another thread to share the dremel pin router.
    http://www.tdpri.com/forum/tele-home-depot/330252-dremel-pin-router.html
    It worked, but not well enough to make very small inlay.
    For this build I'm thinking of scrapping the headstock inlay,
    as the headstock will be painted black and I don't have
    a feeling for whether I'll get good results scraping the
    black lacquer off the inlay.
  11. flatfive
    Monterey, CA
    Back at it! Spread some black Timbermate filler over the body
    and neck.
    The body had previously been sealed with shellac.
    For those of you who weren't born when this thread
    started: the plan's for a sunburst.
    I'm faking it here, but my plan is to spray the front
    and back with yellow Mixol mixed with a little honey
    amber Transtint dye. I want a touch of the black
    filler in the grain to show through the yellow, like
    on my old Melody Maker.
  12. flatfive
    Monterey, CA
    I don't really know what I'm doing with grain filling. The
    last time I used Timbermate I couldn't tell when to stop
    sanding and sanded too little filler off.
    This time I tried to keep sanding until the wood was
    mostly it's natural color.
    Wiped some shellac on to try to see if the color looked
    about right.
    That looks about like I remember my old Melody Maker looking.
    If weather and time permit I'll spray with vinyl sealer tomorrow.
  13. Bentley
    Bentley Friend of Leo's
    Kelowna B.C, Canada
    That looks like a tonne of filler to sand off!
  14. flatfive
    Monterey, CA
    Sprayed Sherwin-Williams vinyl sealer.
    I've never used it before, and it's thicker than I expected
    out of the can. Next time I'll thin it a little.
    You can see some remaining filler on the side and around
    the neck joint. That's okay -- on these areas the burst
    will be dark, and the filler did a good job of fixing little
    problems.
  15. adirondak5
    adirondak5 Wood Hoarder Extraordinaire
    Long Island NY
    Looks good Glenn , I use SW K 27 Retarder Thinner with the vinyl sealer Glenn , its not cheap , cost about the same per gallon as the sealer , but it is good stuff , sealer sprays on smooth like glass , and works great with the Lovoc too .
  16. flatfive
    Monterey, CA
    Thanks, Herb! I actually got some of that thinner at the
    same time as the sealer -- I think Guitarnut recommended
    it to me for blushing problems. I'll try it on the next coat
    of sealer.
  17. kwerk
    kwerk Poster Extraordinaire
    New Zealand
    Looks fabulous, Glenn!
