Meguiar's Ultimate Compound Vs. Ultimate Polish
Discussion in 'Finely Finished' started by mulic3, Nov 5, 2013.
  1. mulic3
    mulic3 Tele-Meister
    Netanya
    Hi guys,
    What would you recommend using after wet sanding? (Bear in mind I also go Turtle wax rubbing compound - The heavy brown kind, so if I should use it also..)
    Thanks alot!
  2. Tom Pettingill
    Tom Pettingill Tele-Holic
    California
    I would not think that they would be mutually exclusive. One is a compound, generally coarser, and the other a polish, generally finer. If it follows conventional wisdom, compound first, then polish.
  3. DrASATele
    North of Boston
    What Tom said... plus. IME It takes both plus 2 additional compounds.
    First: Meguiars Mirror Glaze #105 Ultra-Cut Compound (or turtle wax compound)
    2nd: Meguiars Mirror Glaze #2 Fine Cut Cleaner
    3rd: Meguiars Swirl Remover
    Last: Maguiars Ultimate Polish
    Very much like wet sanding but with pads and buffers. I've had good results with these. A lot of guys use the 3M system which might be one less step/compound.
    I think since you are using the turtle wax that you can then move on to the 2nd, 3rd and 4th steps.
  4. Drum Strummer
    Drum Strummer TDPRI Member
    Tampa, Florida
    mull3c,
    I had great results with Meguiar's. After 1500 grit wet sand - Scratch X 2.0, Swirl X and finally Ultimate Polish.
    I've got pictures posted on the psot Tele-Build - Let the Fun Begin.
  5. mulic3
    mulic3 Tele-Meister
    Netanya
    Thanks a lot guys.
    Drum Strummer, You did a great job!
