Mechanics...help me with oil pressure gauge
Discussion in 'Bad Dog Cafe' started by charlie chitlin, Nov 7, 2019.
  1. charlie chitlin
    Kimberton
    Bought the $30 budget one.
    I know...but it SHOULD work anyway!
    Screw the adapter into the block, pop on the quick connect, fire it up... nothing.
    Same on another vehicle.
    Find tools to work on new tool.
    Grrrr.
    Put air hose in gauge alone.
    Needle moves.
    Check.
    Can NOT get air to go through hose.
    Remove little Schrader valve core from hose...now hose is hollow and air moves through it freely.
    Try a different valve core...same problem.
    Pressure hits this valve from outside and is obviously meant to push it open (unlike in an inner tube where pressure holds it closed).
    So...the 90+ psi from my air hose will not push that little valve open and let pressure get to the gauge.
    WTF?
    There's something going on here that I'm not getting.
  2. Uncle Bob
    Uncle Bob Tele-Holic
    West Virginia
    The oil pressure gauges (both cheap and expensive) I've installed don't have a valve in the line, just a thin line that uses a compression fitting on the block and gauge. I don't understand why it has a valve in the line.
    boris bubbanov and telemnemonics like this.
  3. PlainAllman
    PlainAllman Tele-Afflicted
    Van Zandt Co, Texas
    Maybe your supposed to remove the valve core before installing? The core may just be there to keep out moisture and debris. Is the fitting reversed possibly?
    Shuster, Andy B and telemnemonics like this.
  4. telemnemonics
    Where is the block tapped for a gauge?
    Is the location a pressurized oil reservoir?
    Oil flowing to the heads etc might not be under pressure.
    Like the water that coming of the faucet is no longer under pressure.
    Not really sure here.
  5. charlie chitlin
    Kimberton
    It's not an installation, it's a tester.
    Shoulda been more clear.
    You take out the switch/sender and screw it in to check the pressure.
    I work on tractors, so everything is like 1950s cars.
    Switch/sender either in the block or on/near the oil filter housing.
    I'm thinking the valve might just help get a constant reading that will keep the gauge pressurized even after shutting down the motor.
    I'll probably try taking it out.
  6. telemnemonics
    Hmmm, if it’s a sensor to an idiot light I’m not sure that’s universally connected to the pressurized portion of the oiling system.
    Might be but might also only sense that no oil is flowing through a passage that doesn’t actually have pressure in it, or not the high pressure found at the pump.
  7. dogmeat
    dogmeat Tele-Afflicted
    Alaska
    the schrader valve is installed in the end of cylinder compression testers because it needs to trap a column of air in the hose to get an accurate number. otherwise, the reading would be low because the extra volume (added by the hose) affects the compression ratio. testing cylinders you have pressures well over 100psi
    an oil pressure gauge doesn't need, and shouldn't have a schrader
    telemnemonics likes this.
  8. telemnemonics
    Might be worth going to a car brand forum to find out what the sensor does and if that location will work with your gauge.
    Lots of hobby mechanic info like here with our brand.
  9. telemnemonics
    Yeah that kind of gauge set up as a compression tester certainly needs that valve to hold the reading.
  10. D'tar
    D'tar Friend of Leo's
    WNY
    The fitting on the end of the hose should open the valve as it is connected. The gauge may have the same valve on it. If it's not doing what you want. "Make it". I would remove the valve core from the fitting and the gauge if all you need to do is get a quick oil pressure reading. 20191107_154355.jpg
  11. charlie chitlin
    Kimberton
    And...it's OK for oil to get to the gauge itself...inside the gauge?
    I can't believe I've been doing mechanics forever and never used an oil pressure gauge.
    Compression gauge...yeah...hundreds of times.
  12. MarkieMark
    MarkieMark Tele-Afflicted
    Eastern USA
    Four and a half decades as a master auto mechanic, and I have never once seen an oil pressure tester with a Shrader valve.
    Just adapter, hose and guage. Maybe a fancy one with a quick disconnect coupler.
    And I have no clue what our friend from Maine is going on about. If you remove the stock sender/switch thats an oil pressure galley. Period.
    Whatcha working on?
    Whats the symptom?
    How can I help?
    rz350, telemnemonics and dogmeat like this.
  13. dogmeat
    Alaska
    there shouldn't be any flow into the gauge...unless it's broken, its a dead end. even if there was some liquid in there it'll drain back out. 40+ years A&P/AI aircraft mech
  14. charlie chitlin
    Kimberton
    Right...duh...thanks.
    The gauge has variously sized/threaded fittings that go into the block (in this case) and the hose snaps on with a quick connect.
    Just downstream, where the quick connect attaches, is a schrader valve core.
    I assume the pressure is supposed to push it open, but it doesn't.
    The machine is a New Holland diesel skid steer.
    The oil light goes on at seemingly-random times and shuts the machine down.
    I strongly suspect an intermittent short somewhere between the sender and the dash.
    This machine is critical to the farm and I need to get it back in service.
    I don't mind bypassing the pressure sender circuit until I can fix it properly, but I want to be dead sure I don't have an actual low oil pressure situation.
  15. bondoman
    bondoman Tele-Holic
    vallejo ca
    First off you don't want any air in the line to the gage. Air compresses whereas oil will not. So even if you did get a reading it would be incorrect. New Holland huh? Wouldn't surprise me if it didn't have an oil pump going south. Worked as a mechanic for a New Holland dealership for 10 years. Have an old 3020 in the fleet at the moment. Biggest POS we have. Work for a county government these days.
  16. Pete Baker
    Pete Baker Tele-Meister
    Maryland
    This may sound obvious, and probably isn't the case, but maybe the New Holland isn't making any oil pressure. Have you tried the gauge on a different engine?
    getbent and boris bubbanov like this.
  17. charlie chitlin
    Kimberton
    Yes...
  18. dogmeat
    Alaska
    air in the line will compress, and the pressure will be the same as whatever it source is. if the source is not steady, the needle will fluctuate
    and ya, may have an oil delivery problem. crack the line and crank the engine & see if oil comes out. install the gauge with no Schrader valve, the pressure may be too low ot open it. thats all I got
  19. charlie chitlin
    Kimberton
    I cracked the line...plenty squirted out.
    I'm gonna pull the valve core.
    getbent likes this.
  20. schmee
    Well, it's been ages but I think oil flows right into a normal old school oil gauge ... into the "Bourdon tube" inside the gage. Not sure air in there is good.. air is compressible... but I guess eventually it evens out.
    Old tractors probably have very low oil pressure, so not sure it will register.?
