May seem funny but I’ll ask anyhow
Discussion in 'Tele-Technical' started by Wes1965, Sep 25, 2019.
  1. Wes1965
    Wes1965 TDPRI Member
    I have an older Squier HH with 22 fret maples board. I am thinking about getting a new neck? My question is can one put a 21 fret neck on it without messing anything up? I am finding that there seems to be more 21 fret necks out there for sale then 22 frets! The price seem to be a tad lower too.
    Thanks for any input!
  2. Mike_LA
    Mike_LA Tele-Afflicted
    Just past 11 on the Dial
    If the length of the neck is longer your original neck the bridge may need to be moved back to intonate properly
  3. G&Lplayer
    G&Lplayer Tele-Meister
    Virginia
    On my 22 fret necks the fretboard overhangs the body, the neck itself ends where it is supposed to.
    rolandson likes this.
  4. Davecam48
    Queensland Australia
    It will depend on the scale length not how many frets are on the neck. Measure from the nut to the 12th fret, that is half of the scale length of the guitar and determines the position of the bridge. Any variation of the existing scale length will require a re-positioning of the bridge or the guitar will play out of tune.
    i.e. Nut to 12th fret = 12.75 inches = standard Tele scale length 25.5". Not all guitars are built using the same scale length.
    If you don't use the same scale you will have to change the bridge, a bigger job than just replacing a neck!
    DC
    sonicsmitty likes this.
  5. RodeoTex
    Nueces Strip
    Should be just fine.
    The only possible difference I can think of is that where the fretboard overhangs the body, the fretboard may be cut back to accommodate it. You can tell if you lift the current neck and peek under.
    Worst case, you might have to get a new standard pickguard.
