Jerry garrcia
And further down the rabbit hole I goBriefly checking it looks Vitaly does not show any Local Cathode Feedback unless he has updated the book?
I thought it would be easy to find more info so I have not bookmarked any pages but it wasn't. Here it is discussed in guitar amps and on post 6 is first "correct" circuit and better drawn on post 28.
Adding NFB to power tube cathode?
Hoffman Amplifiers Tube Amp Forum, Adding NFB to power tube cathode?el34world.com
CFB using OT secondary in cathode current circuit is not very effective but better than nothing.
Perhaps you should buy Ultralinear OT because it work!
If you don't like amp coming heavy then Mennovanderveen toroid SE OT are lightest and they have UL option. Menno used to stock some 12W SE in Holland but two other OT I have bought came direct from Romanian factory so postage was bit higher and tax increased the price some more. He reply emails fast so you can ask if any are on EU sell?
I have used VDV-2512-SEE (only 955g) in few circuits and test UL as well. UL did not improve "my guitar sound preference" but if low distortion is needed it work very well. I did test EL34 for about 12W, KT66 about 13W and KT88 about 15W and all made very loud sweet sounding amp. So I bought VDV-1324-SEE (only 1750g) and going to drive it using KT150 but have not build it. It should be able to produce even 30W when impedance is set to 2,5k, bias is 160mA and B1 450VDC. It lists only 99 euros but it came from Romania which increased its price but I don't remember how much?
Toroidy.pl OTs are heavy but for guitar frequency range should be able to produce double the rated power. Not to exceed max bias using higher voltage and possibly doubling the impedance ot using parallel tubes is needed and then their weight comes reasonable. Anyone who want a monster SE guitar amp the TTG-6C33CSE 600mA bias is enought for even six parallel KT88
Best buy conventional SE OT should be Tubetown 2k5-5/4-8-16 for only 61 euros if it is good for 160mA bias. That OT is very high on my build order after I finish two builds.
Since I’m sitting with my 125ESE OT I might as well use it and try the UL tap if not satisfactory. You are just an endless well of knowledge.
Now I’m trying to find which of my PT’s that can handle two preamp tubes and a 6L6 with +420VDC. Don’t want to use one that has a 5V winding since I’m going SS.
An EAM86 would be fun to use in some way in the circuit. @2L man
Edit. You are correct. He described the UL configuration not local cathode feedback. But you delivered it to me though the EL34 world. Thanks!
