Jerry garrcia
I’m planning a build of a small sized amp that will be placed in a tight cabinet.
- 12” speaker (15 ohms),
- SS rectifier,
- 125ESE OT and will have to use the 5K primary for a 16 ohm speaker,
- PT from a reel to reel tape recorder that puts out around 265 VAC (so probably around 360-370 VDC).
- Single 6L6 power tube
- 6SJ7 preamp tube with @printer2 bias switch between grid leak/cathode bias.
- NFB and boost switch (when in cathode biased mode).
- Princeton tone stack
- an extra 47uF filter stage before B+ node.
Initially I wanted to go PP but it will not fit very well in the closed cabinet.
The goal is as usual to get maximum cleans out of the 6SJ7 but now also maximum volume out there fore the 6L6 (have some EL34’s and a KT 120
(but a bit to big).
Read somewhere that a single 6SJ7 will have problems to fully drive a 6L6 to maximum output (probably 350V on the plate).
1) Is that correct?
2) If so should I add an extra gain stage with a tube that can drive the 6L6?
2) If so which tube should I use to do so but still keep the maximum cleans? I have some 6SQ7’s, 6SK7’s (could triode wire it) and 6SN/SL7’s (don’t care to much to use them since I hate to only use half of a tube).
Any inputs appreciated.
- SS rectifier,
1) Is that correct?
