Fender_Player90
I added a 5B5 10 way Freeway Switch to my Strat and after playing with various tone pot setups (neck/middle/bridge no tone and then neck/middle no tone/bridge)....I settled on wiring the 1st tone pot as a master tone and wired it 50s style to the center lug of the Volume pot. I like it best this way. With the 2 tone controls, some weird things happened in the series settings and I just didint care for it. Master tone gives all three pickups a tone control through one quick easy adjustment and I think it sounds better since its simpler wiring and there is no double loading of pots in any position.
That being said currently my second tone pot is hooked to nothing and id like to use it for something. Its a no load pot I was originally using for the blender mod prior to breaking down and buying the 10 way switch. But would like to use it as an extra feature for something I can turn off and remove from the circuit. Is it possible to do the blender mod with the 10 way switch? I know I have the neck and bridge setting but I would be doing this to get the neck partially blended in with the bridge? Another thought is a master treble and master bass cut. Isnt the master tone basically a treble cut so I could add that no load pot as a bass cut and then turn it off when I dont want to use it (turn it up to 10) and have a normal master tone so to speak?
