Aftermath
I never thought it was that special, but looking back on some of the recordings I did with it, it was a pretty cool pedal. Any tips on what would be a good pedal to replace it with?
It just won't turn on. no sound or lighting up.Should be easy to fix. What are the symptoms?
Did you ever get it fixed?I never thought it was that special, but looking back on some of the recordings I did with it, it was a pretty cool pedal. Any tips on what would be a good pedal to replace it with?
yeah, I think I will. It definitely has that low end crunch that sounds great when you mute the bass strings. I do punk/post-punk/hard rock so it definitely is great for that. I was thinking about getting a fulltone ocd in the mean time though. Would you recommend any other pedal?Did you ever get it fixed?
Back in '91-'92 when those first came out I never heard anything heavier stompbox wise at that time. I was playing in an originals thrash band in late '92 - early '93 and the other guitarist was using one through a solid state PV Musician 400 head and 412 cab and his sound was massive for that genre. I wanted one desperately back then but never did get one.
I think there is some value in those old Marshall pedals and I'd try to fix it if it were mine.
Based on my 30-year-old memory of the Shredmaster and being an owner of an OCD I would seriously recommend a Pro Co Rat 2 which I also own for something more in the ballpark of the Shredmaster. $65-$70 new.
I'm gonna tag @11 Gauge on this one as I believe he is a fan of the pedal and may be able to help in other ways as well.
Got a soldering iron? BYOC kits are top-notch.
Shredder
Sometimes there's a thin line between what's an overdrive, what's a fuzz, and what's a distortion. The Marshall Shredmaster is definitely a full on 80's heavy metal distortion. But it also has the dynamics to pull off a very nice overdrive tone as well. The BYOC Shredder kit packs all the tone...buildyourownclone.com
