Marshall Jackhammer thumbs up
Discussion in 'The Stomp Box' started by trxx, Feb 26, 2021.
  1. trxx
    trxx Tele-Afflicted
    Between reality and imagination
    I'm liking it in front of my Super Reverb for getting into Marshall territory. And that cheap ass Candy Floss pedal sounds good with it too for loosening things up. The Jackhammer alone gets in JCM800 territory and with the Candy Floss more like JTM45 territory.
    The thing feels like a brick. The knobs are shiny chrome though, and it can be hard to see the position. It's going to take some fiddling to get used to the mid knobs but they seem effective in shaping things.
    uriah1 likes this.
  2. blowtorch
    Wisco
    yep great MIAB pedal and it's do all kinds of different flavors or Marshall, too .
    The shiny nuts on the jacks can pretty easily unscrew themselves.
    Awesome sounds though.
    One of the best-kept secrets in the pedal universe
  3. trxx
    trxx Tele-Afflicted
    I'm surprised that it does overdrive so well and also does high gain well. Every mention of this pedal cited the distortion mode sucking, but I really don't understand why it catches so much flack. The distortion mode sounds just as good as the overdrive mode to my ears. This pedal essentially does clean boost to high gain, all well to my ears. The overdrive mode is not like a tubescreamer type with a clean component and rolled off lows and highs. It's full range but with a Marshall voicing. The distortion mode is like a way better DS-1 with a Marshall voicing.
  4. trxx
    trxx Tele-Afflicted
    Twisting the knobs every which way, this thing has alot of usable sound in it. Clean, edge of breakup, overdrive, mid gain, heavy gain. The people who complained about the distortion mode didn't twist the knobs enough. If you leave the knobs up the middle it sounds scooped in distortion mode. If you bring down (way down) the contour and freq mid knobs, it gets into the same territory as the overdrive mode but with tons of gain on tap. Go from there and remove mids if you like.
  5. telemnemonics
    I've never tried that one but I have the Grandma and Grandpa.
  6. telemnemonics
  7. Sleepyscholar
    Sleepyscholar Tele-Meister
    Nagoya, Japan
    I have both a Shredmaster and a Jackhammer, and I have to confess that I see it more as father-and-son relationship. The OD side of the Jackhammer is pretty close to the Shredmaster -- not quite as good, but close. The distortion side strikes out on its own.
    telemnemonics likes this.
  8. telemnemonics
    Interesting, Marshall considering something like the Shredmaster an OD, not that it's that distorted but times sure do change!
    Sleepyscholar likes this.
