Marshall Haze Channel Switching
Discussion in 'Amp Tech Center' started by IanC_UK, Feb 25, 2021.
  1. IanC_UK
    IanC_UK NEW MEMBER!
    Hi. Anyone any idea what could be causing my Marshall Haze 15 head to switch channels ok with the footswitch but not with the front panel button?
    I've unplugged the footswitch and no joy switching channels...tried cleaning the switch mechanism and still nothing
    Other than the above, the amp works fine and sounds great
    Cheers,
    Ian
  2. goldguitarguy
    goldguitarguy Tele-Meister
    Alberta,canada
    Probably a bad switch
  3. goldguitarguy
    Alberta,canada
    Did you try cleaning the shunt contacts on the TRS jack for the foot switch? Or inspecting the foot switch jack? If those shunts dont contact properly after the foot switch plug is removed the amp acts like the foot switch is still engaged bypassing the panel switch....
    IanC_UK likes this.
  4. IanC_UK
    IanC_UK NEW MEMBER!
    Cheers goldguitarguy, much appreciated. Makes a lot of sense and sounds like a job for a Saturday morning with a coffee.
