Marking the half-step bend? Plus Clarence's Nudie sticker
Discussion in 'B-Bender Forum' started by kram29, Jul 12, 2020.
  1. kram29
    kram29 TDPRI Member
    AZ
    I was working on some half step bends and I couldn't help but think using a marker would help learn the spot better. Has anyone does this?
    In a related note, I was wondering if Clarence's Nudie sticker helped him in this regard initially. "Half-step is dead center of the hat" kind of thing? Thoughts?
  2. kiwi blue
    kiwi blue Tele-Afflicted
    Wellington, New Zealand
    Edited. Never mind. I didn't realise this was the B Bender forum. Carry on.
  3. Rick Towne
    Rick Towne Tele-Afflicted
    Woodland Hills, CA
    A precise half step bend is quite easy on my Glaser because of the shorter pull.
    That Cal Webway and kram29 like this.
  4. string pull
    string pull Tele-Meister
    Fairfax,Va
    Clarence was a fashion icon. Show biz baby.
    rod and That Cal Webway like this.
  5. telemnemonics
    Us mere mortals have no clue...
    Wallaby and Fretting out like this.
  6. fenderchamp
    fenderchamp Tele-Afflicted Silver Supporter
    omaha
    I don't play any b bender, but I can't help but think one's ear is the way to go, other than a mark that you have to look at. But maybe I just don't understand
    asatfan and telemnemonics like this.
  7. kram29
    kram29 TDPRI Member
    AZ
    Not easy when doing faster stuff, at for least me.
  8. Wallaby
    Wallaby Tele-Afflicted Silver Supporter
    Midwest
    I thought the throw could be adjusted to make the correct bend precisely?
    I know next to nothing about using a Bender, I apologize if my comment is really ignorant.
  9. ChrisLarcombe
    ChrisLarcombe TDPRI Member
    Midlands, UK
    While it's true that you could potentially adjust the throw so a full bend only raises the note your fretting by one semitone, if you were to pre-bend and begin to let this down as Clarence normally does when utilising a half bend, you'd obviously not be able to continue the bend down to a full 2 semitones, as is with a normal bender set-up, so you'd be sacrificing a lot of standard shapes and practices.
  10. ChrisLarcombe
    Midlands, UK
    I think the easiest way is just doing it enough times on the same setup so you develop muscle memory for it. And obviously your ear is also almost just as important when using half bends, espiecially at slower tempos. Even if your muscle memory tells ya it's right, if the note is sharp or flat, ya gotta adjust, end of.
    scook likes this.
