gb Custom Shop
I started a new build a couple weeks ago, and there are some new things I'll be trying out here. What better place to document all this!?
The inspiration for this build is this custom shop fender with the burl top and herringbone purfling. It's well outside my budget, so I've elected to build my own.
I'll be using maple burl for the top, and torrefied ash for the body. The top has quite a few imperfections that will need to be addressed, and that's where I started.
I started by cleaning out all the little soft, brown spots. I bought a cheap set of dental picks just for this task. They were helpful, but for slightly bigger areas, I found the Dremel with a mini carving bit to be much more efficient. Once that was done, I cleaned everything up with a brass brush. All in all, this took hours!
After all that was cleaned up, it was time to fill all these imperfections. The reason I'm doing this now at this stage, is because some of these imperfections go all the way through the top. And since this will be a thinline, it needs to be addressed before gluing on the top. So I masked the backside of the top with tuck tape.
Then I mixed up a slow cure epoxy with some black mica, and filled in all the holes.
Thankfully I got no leaks! Once it cured, I cleaned it up at the drum sander. That revealed a few more imperfections that I just addressed with CA and mica.
Lastly, I routed out the f hole and control cavity, at which point the top is ready to be glued to the body.
