So I've done some searching and haven't found the answer I'm looking for. Also I'm still learning about amps and building/repair. I am a novice so go easy on me.
I had a brain storm and was hoping you could pull me from or push me off this ledge. Is it possible to make a Fender Twin (4 x 6l6, 6 x 12a_7) into a true stereo amp? Essentially a 1 channel Pro Reverb (2 x 6l6, 4 x 12ax7) and a 1 channel Pro (2 x 6l6, 2 x 12a_7) using a single 12” speaker for each.
My conversion thoughts so far:
You would need a separate output transformer for each side
The power transformer is big enough to run the 6.3v heaters
The rectification would work for all the tubes
Questions I am unsure of:
Will the grid stopper resistors isolate the B+ so that there is no signal bleed between the two sides?
Can I use a single B+ to run two separate amps?
I think it would be rather cool to be able to have that perfect Fender tone and run Stereo, Wet/Dry, or Dual Mono (whatever you want to call it) out of the same amp. I know it'll be heavy and that's ok with me.
Also, if they made tube stereos for home audio, there must be a way. Did they have a different style of power transformers?
