Mahogany Esquire
Discussion in 'Tele Home Depot' started by Scatter Lee, Feb 11, 2011.
  1. Scatter Lee
    Scatter Lee Friend of Leo's
    follow the buzzards
    I started this build with the tdowns Rev E blueprint and made me some new plexiglass templates
    took me four days to make these, they are sweet
    I have a one piece Honduran Mahogany blank just sitting around so.......why not,
    routed with no tearouts
    did I mention it will be an Esquire? :twisted:
    routed out a strat pickup template
    and then used it
    used the new template to route the bridge pickup cavity and control cavity
    I had to raise the template 3/8" off the body so the router bit could do the neck cavity
    it did a good job
    then drilled the output jack hole
    still wondering if I should use a Maple neck or make a Mahogany one :confused:
    :twisted::cool:
  2. adjason
    adjason Friend of Leo's Silver Supporter
    virginia
    Great looking guitar. I would go with a maple neck -too much mahaogany can take it into un fender territory and it just doesnt quite look right on a fender style guitar.
  3. Colt W. Knight
    Tucson, AZ
    I say mohoghany. Maple necks get boring after a while.
  4. Maricopa
    Maricopa Friend of Leo's
    Phx, AZ
    Mahogany neck, rosewood board.
  5. CapnCrunch
    CapnCrunch Friend of Leo's
    Washington, USA
    +1
  6. TheZ
    TheZ Tele-Meister
    Memphis, TN, USA
    What he said
  7. kwerk
    kwerk Poster Extraordinaire
    New Zealand
    (little yellow popcorn dude here)
  8. xbearxau
    xbearxau Tele-Meister
    Melbourne, Australia
    Hey Scatter, if its not too off topic, would you mind telling us how you machined the plexi? Did you just cut close to the size and use a regular template router bit? Ive got to make some new templates and have some plexi lying around just not sure how it handles the router.
  9. Keyser Soze
    Keyser Soze Tele-Holic
    Johnson City, TN
    Mahogany neck, pau ferro board.
  10. treadwm
    treadwm Tele-Meister
    Brunswick, Maine
    Ditto!
  11. 4string
    4string Friend of Leo's
    Central California
    Heat is a big issue when machining plastics. Too much and it melts rather than cuts. Hi-speed sanding like drum sanding is out. RO is ok.
    For routing, I recommend cycling the cutting to allow the bit to cool. When a router bit is spinning without cutting it will air-cool. You should be able to touch a bit (when it's not spinning obviously) without burning your finger or it is too hot for plastic.
  12. misterecks
    misterecks Tele-Meister
    Nottingham England
    Looking very nice as usual. Just to be different I say maple neck, a big fat one :D
  13. Ironhide
    Ironhide Tele-Meister
    Dublin
    If you're not gonna stain it too dark then I say maple like this one. Otherwise definitely mahogany neck and rosewood fretboard. With brass hardware and black tuner buttons (trust me it would look killer!)
  14. melomanarock
    melomanarock Tele-Holic
    Argentina
    Just go crazy and use both.. mahogany neck, maple fretboard
  15. brewsterallen
    brewsterallen Tele-Meister
    Road Eyelend
    OMG he is UNSTOPPABLE. I AM NOT WORTHY. But I sure will watch and steal, UM, I mean borrow some ideas !
  16. Scatter Lee
    follow the buzzards
    I made wood templates first then cut the plexi close with a saber saw then used the wood templates to route the plexi with a regular router bit, the plexiglass is 1/4" thick and I had no problems
  17. Scatter Lee
    follow the buzzards
    the neck screws on so I'll probably try a couple different woods
    I drilled some holes today, the drill press got the outside holes then i screwed on the bridge and used it as a template to drill the rest. used the hand drill with 3/8" bit for the counter sunk part on the string ferrules, then used my fingers and a 5/16" bit to drill the depth by hand, the bit was so sharp it would just corkscrew into the wood with the drill so i did it by hand measuring depth along the way
    Did some ironing with a wet cloth to raise the grain and sanded the body down to 400 grit and brushed on some sanding sealer
    still not sure what color to do the body, maybe a transparent Blonde or Yellow :confused: maybe :confused: still have a couple of holes to drill
    :twisted::cool:
  18. three barrel
    three barrel Tele-Meister
    Wichita, KS
    Clear coat it. That grain is killer! Lots of tonal variations already.
  19. free2rock
    free2rock TDPRI Member
    Philippines
    Looking great! Excited!
  20. OpenG Capo4
    OpenG Capo4 Friend of Leo's
    Athens, GA
    I'd go with a walnut or cherry color on the body, and a vintage amber tint on a maple neck, with a rosewood board.
