woodandglue
Hi all!
I built a Magnatone 210 /410 with reverb added and it all works, except the vibrato. Ha! There is no noticeable wa-wa-wa except from me.
I measured the oscillator's plate voltage and it is certainly changing. The grid voltage on the oscillator is supposed to be -2.2v and I measure 1v. Do I need to change that, and if so, how? I've checked for continuity throughout the circuit and checked for shorts to ground all over. I’ve rolled different 12au7 and 6N2P (Russian 12ax7 with different heater pins). I've included the schematic as built and included the voltages from both the original schematic and from the amp. The top red voltages are from and the bottom voltages are what is on the original schematic.
This is a repurposed radio so I needed to change some resistor values in the power section to get the voltages closer to the schematic. I also removed the .02 capacitor between the varistors (as suggested by Psionic here ), but have experienced this issue with and without this cap. If there is a thread where the answers already exist, I will gladly delete this one. Your insights are greatly appreciated. I will gladly measure or check just about anything you ask me to!
