¡Bueno!™
MY bread and butter are these simple rings photo below. They are 6mm wide bands, parallel sides. I've been using a Covington wet sander. As you can see in the photo the hard water in the SW has killed it. There was a platform that sits square to the belt and I could put a perfect flat spot on the rings to quickly solder to a back plate. Clean and square. It's aluminum but actually broke off. Not only the hard water but they used a steel bolt which reacted with the aluminum. Please see the brand new photo of what it's supposed to look like.
This one cost me ~$300 ~3 years ago. Now $450! Plus it was never the perfect tool for the job. They are not designed for a solid stable 90° bed but adjustable. So a challenge to keep squared up.
I've been trying to find an alternative to do this. I did it by hand yesterday; a file and a perfectly squared clamp (engravers block) and it works but ~5 minutes compared to 5 seconds.....I've used woodworking disc sanders in the past but they sandpaper never lasts as it gets too hot and not made for water cooling.....
The $450 does hurt too bad but I'm taking the opportunity to consider other options.... I've been using these machines for years and never had one fail like this one. Even in the SW..... I'll at least have to modify with stainless steel or other non reactive bolts
Any ideas?
Thanks!
Any ideas?
Thanks!
