lubricating screws...
Discussion in 'Tele Home Depot' started by joeford, Oct 2, 2019.
  1. joeford
    joeford Friend of Leo's
    st. louis, illinois
    i like a bit of a fight when I'm bolting parts together... gives me a little more confidence that things will stay put down the road. BUT... I've also broken off more than my fair share of screw heads...
    I'm thinking about lubricating the screws on my current build... but won't that also make things easier to come apart? the lubrication works both ways, right? would i be better off just opening the pilot holes a bit more vs keeping things more snug and lubricating? any tips?
    also... I'm aware that this topic is a giant "that's what she said" joke
  2. guitarbuilder
    guitarbuilder Telefied Silver Supporter
    I use canning wax. I just rub it on the threads. Find a pilot hole chart for screw size. Fender imperial size is #8. You'll notice in the chart that softwoods go down a notch from hardwoods. That's relative to wood density though, not necessarily wood hardness. Some conifers would be harder to put a screw into than some hardwoods. Here's an example chart:
    https://www.boltdepot.com/fastener-information/wood-screws/Wood-Screw-Pilot-Hole-Size.aspx
  3. Hobs
    Hobs Tele-Meister
    Nashville, TN
    Use beeswax to lubricate them. They will go in easier, but it doesn't seem to make them loosen on their own. Oversize pilot holes will weaken the connection between the threads and the wood.
    joeford, djh22, Deeve and 1 other person like this.
  4. 4pickupguy
    4pickupguy Poster Extraordinaire
    Fort Worth, Texas
    Yup beeswax...even Ivory soap will work in a pinch.
    joeford, djh22 and coloradojeff like this.
  5. Vanzant
    Vanzant Tele-Afflicted
    United States
    beeswax
    joeford likes this.
  6. jkingma
    44°55'09.9"N 79°25'39.1"W
    Admin Post
    I use conservators wax. I found a small tin of it in my basement years ago (it was probably there when we bought the house) and didn't know what it was for so decided to use it to lubricate the screws on my guitar projects.
    joeford likes this.
  7. ale.istotle
    ale.istotle Tele-Meister
    Pennsylvania
    I draw the screw threads across an old candle. Doesn't take much.
  8. LowCaster
    LowCaster Tele-Holic
    Paris, France
    Wax, or soap... Candle wax, beeswax. Don't use grease or oil.
    You need to take some extra time to drill your pilot holes just the right size. It depends on the wood, make some tests on scraps of wood before. You don't wan't an oversized pilot hole, but when working with harder woods (ebony, maple, roasted woods) your pilot hole should not squeeze the core or the shank of the screw, it has to be just right to accomodate the core diameter of the screw.
    Remember that it's the threads that are holding the screw in the wood.
    One trick is to have a few drill bits with slight differences in diameter.
    joeford and howardlo like this.
  9. VintageSG
    Yorkshire
    They won't work loose. Think how much torque it takes to drive the screw in. This deforms the material around the thread as well as cutting the negative. The contact pressure on the threads will hold against the piddly amount of vibration a guitar generates.
    Lube it up!, don't go in dry and fast ( Fnarr! )
    joeford likes this.
  10. WingedWords
    WingedWords Tele-Holic
    UK and EU
    Worth saying again: special care with pilot holes in roasted maple. It splits so easily.
    joeford likes this.
  11. intensely calm
    intensely calm Tele-Meister
    Bee's/candle wax and/or bar hand soap. (not the pump hand soap, too oily)
    I typically pre-thread each hole using a sacrificial screw that has been wax'd.
    get some threads in the wood before final assembly, makes life easier.
    Saves screw heads, and there are fewer slips and scratches.
    If the wood has been used and abused, the hole is loose but not to the extent of needing a drill-n-plug -
    I may wick CA into the wood hole then wax a screw and thread it in.
    Let it set for a short bit and remove the screw before the CA completely sets.
    The slight waxing will allow the screw to be removed easy enough.
    The CA will harden the threads in the wood... sorry a bit off topic
    joeford and magicfingers99 like this.
  12. magicfingers99
    magicfingers99 Friend of Leo's
    atlanta
    I wax the whole guitar and put the screws in dry, I think it saves time waxing all those screws, but sometimes it gets out of hand and I wax the car and the appliances and the countertops and the floors and never get around to the guitar.....
    joeford, EsquireBoy and MickM like this.
  13. Preacher
    Preacher Friend of Leo's
    Big D
    Use this, the nice smell is an extra benefit!!
  14. Verne Bunsen
    Verne Bunsen Tele-Afflicted
    Sonoran Desert
    I use bar soap.
    matmosphere, joeford and RodeoTex like this.
  15. Ronkirn
    Jacksonville, FL
    I use whatever's in reach.. usually TreeWax, Minwax Finishing paste wax, or the "go to" Bee's Wax. which is pretty much the industry standard among furniture makers...
    and.. for those that are not "lubing" the screws... Whut, You Nutz... :p always drill a pilot hole and lubricate the screws into all but the softest woods....
    and the screws that come with most parts are at the bottom of the list in quality... throw 'em away unless you just plain cannot find replacements from somewhere like McMaster-Carr.. they are constantly expanding the varieties they carry, but good old Stainless Steel works for most of us.... the Cheep stuff can strip, or snap off faster 'n you can say, "Dawwgone, I hate it when that happens".
    r
  16. raito
    raito Poster Extraordinaire
    Madison, WI
    Yes, lube always. And I just end up buying a Callaham screw pack so I have at least enough to finish a build. If I were building more than one-offs, I might try sourcing my own.
    joeford likes this.
  17. schmee
    schmee Poster Extraordinaire
    Wax, I just use Burts Bees Wax in the tube! Guitar components have no reason they should loosen up.
    joeford likes this.
  18. 1bad914
    1bad914 Tele-Holic
    Michigan
    A bar of white ivory soap is on the ledge above my bench. Use it for every screw going in wood, never had them come loose because of the soap.
    joeford likes this.
  19. Ronkirn
    Jacksonville, FL
    Yeah, like those strap buttons, and jack cups.... :p
    rk
    joeford and Piggy Stu like this.
  20. Ricky D.
    Ricky D. Doctor of Teleocity
    Raleigh, North Carolina
    Bar soap or candle wax always. I just keep it wrapped in waxed paper in my toolbox tray.
    joeford likes this.
