LPish Tele suggestions
Discussion in 'Tele Home Depot' started by Capel, Apr 15, 2009.
  1. craigoslo
    craigoslo Tele-Meister
    oslo, Norway
    I think it does have some importance, but what I think is more important is neck angle, especially for feel.
  2. uOpt
    uOpt Tele-Meister
    Boston
    I see several problems with this project.
    A thin flat maple veneer is not the same thing as a carved maple top. If you don't want to go through the trouble of carving one I would rather go with pure a pure mahogany body, and it must be closer to 2" than 1-3/4". A thin veneer can easily be nothing else than a dampener. I would give it a LP-ish look with body binding.
    You need to be careful about the APH pickups. They sound great, sure, but the bridge pickup is much brighter than a person who casually picks up Gibson Les Pauls in a shop expects. Better ask that person which LP specifically he liked. Your choice of pickup will be the most important factor in his/her judgement whether the guitar came out "correctly". The APH neck is comparable to a 490R and most LPs have the 490R, so that should be fine.
    You might want to consider a high neck angle and a tune-o-matic with stop tailpiece. A string-through body will change things. For a flat bridge the Schaller flatmount is probably better. Looks better, too.
    Whether a mahogany neck is required or not is a different matter, it's probably less important than the other factors.
