LP Style Walnut and Maple Build
Discussion in 'Tele Home Depot' started by thecableguy, Nov 15, 2014.
  1. thecableguy
    thecableguy Friend of Leo's
    Sherwood Park, Canada
    Hogged it out with a router bit with a bushing on the router.
    Finished the pocket with a flush trim bit. Sanded the sides of the neck until it fit the pocket.
  2. thecableguy
    Did the neck carve with a spokeshave and a template sander in a hand drill.
    Did this part on the ROSS.
    Cleaned up the volute with the sanding drum in the drill method.
  3. Greg M
    Greg M Tele-Holic
    Virginia
    Looks great! Love the smooth neck transition.
  4. Crowcaster
    Crowcaster Tele-Holic
    North Dakota
    Very Nice! I'm subscribed.
  5. thecableguy
    Made this circle template
    To use with this bit and bushing
    Alignment tool
    Dished out the knobs and switch areas.
  6. thecableguy
    Glued in the neck.
    Made sure the area next to the neck is free of glue so the dye will soak in.
  7. thecableguy
    Routed the pickup cavities. I designed the template to use a 3/8" bushing with a 1/4" bit so I could get a tight radius on the corners.
  8. I_build_my_own
    New York
    Wow!!! Very nice and clean build!!!
  9. guitarbuilder
    I like the contemporary look. That maple is wicked looking.
  10. thecableguy
    Thanks very much!
    Much appreciated, thanks!
    Thanks for the interest!
    Appreciated, thank you!
    Thanks again Marty! The top is from Fraser Valley Fine Woods in British Columbia.
  11. BluesBlooded
    BluesBlooded Friend of Leo's
    Sherbrooke, Qc, Canada
    Very impressive workmanship Brian! That is a gorgeous build. Well done!
  12. oldrebel
    oldrebel Friend of Leo's
    Lynchburg Tennessee
    That looks fantastic Brian!! Great work.
  13. Brian J.
    Brian J. Tele-Afflicted
    pennsylvania
    that s bad ass, can't wait to see what it looks like when it gets a finish on it. are you going to do your own finishing as well, or will you send it out?
  14. Richard Guy
    Richard Guy TDPRI Member
    Virginia
    No CNC, yippee! Super attention to details. No BS, Artwork, it already sounds great to my eyes. ;)
  15. KWhatley
    KWhatley Tele-Holic
    London, UK
    Very nice work mate. I really like the modifications you've made and incorporated into this. I already had the dished out buttons in mind for mine when I get round to it so thanks for the method you've shown.
  16. thecableguy
    Thanks Andre!
    Thanks Reb!
    Thanks Brian, yeah I'll be doing the finishing. The top will be dyed blue and the whole thing will get sprayed with water based lacquer.
    Thanks Richard. I do plan on building a CNC after this build. :D
    Thanks Kevin. The bowl and tray bit works very well and using it with a template bushing allows you to get it the exact right size.
  17. thecableguy
    I did a few dye tests the other day.
  18. thecableguy
  19. BluesBlooded
  20. thecableguy
    Yeah I used it on the last build. It's nice to work with.
