LP Style Walnut and Maple Build
Discussion in 'Tele Home Depot' started by thecableguy, Nov 15, 2014.
  1. thecableguy
    thecableguy Friend of Leo's
    Sherwood Park, Canada
    I started this project in September and I just haven't gotten around to posting it. This is a Les Paul style build with walnut, a figured maple top and a 3 piece neck.
    Body blank jointed and glued:
    Maple top from BC:
    Wood for the neck:
    Cut out the center piece for the neck. Sanded it on the ROSS and used it as a template for the outer pieces.
    Glued up, cleaned up the face and routed the truss rod slot.
    Glued on some ears and cleaned up the headstock face.
    Made a headstock template and routed the outline using a 1/4" bit and a router bushing. Made multiple passes to cut out the headstock and then flush trimmed to the template.
    Made a template for routing the sides of the neck and routed it flush.
  2. thecableguy
    I took the body blank in to the guy I bought the wood from to have it planed / drum sanded to thickness. Made a template and routed the electronics cavities and wiring channel.
    Took away some unnecessary weight.
    Cut out and flush trimmed the body.
  3. skipjackrc4
    skipjackrc4 Tele-Meister
    Subscribed! Walnut and maple is probably my favorite combination of woods. Except for possibly cocobolo and maple.
  4. thecableguy
    I also had the top touched up on a drum sander.
    Cut out, glued, and flush trimmed.
    My $70 jointer with new $25 blades works quite well.
  5. thecableguy
  6. thecableguy
    Routed the neck plane and pickup plane. I drew it up in CAD first to make sure the strings sit parallel to the pickup rings I'm using. Ended up with the pickup plane 2 degrees off horizontal and the neck plane 4 degrees off horizontal.
    After a bunch of quality time with a scraper, orbital sander and palm sander:
  7. thecableguy
    Couple ebony fretboards off ebay.
    Cut the slots and did a 12" radius on the jig.
    Fret markers:
  8. guitarbuilder
    This is a nice build. I'm tempted to try a top like that with the different plateaus just because.... That curly looks about 2" thick with that angle... I bet you were a bit nervous for a while?
  9. thecableguy
    Thank you sir!
  10. thecableguy
    Thanks Marty. The top is 1" thick. Yeah I took the terrace routing slow.
  11. thecableguy
    Made an overlay for the headstock.
    Used a router to square up the end of the overlay where the nut will sit.
    Routed a binding channel.
    Glued on the binding with acetone.
  12. thecableguy
    I used my binding bit to make the fretboard template 1/16 smaller than the neck template on each side. Routed it and glued on some binding, again with acetone.
    Scraped and sanded the board smooth.
  13. thecableguy
    Fretting the board. I got a fret press caul and fretwire tang nipper off eBay.
    Filed the fret ends.
    Drilled for side markers.
    Punched them out of scrap binding.
    Put them in and applied a drop of acetone to each one to weld it in place.
  14. R. Stratenstein
    Loganville, Ga.
    Beautiful, Brian. Impressive work. :D
  15. '59_Standard
    '59_Standard Tele-Holic
    Worldwide
    Nice clean work!
  16. lbridenstine
    lbridenstine Friend of Leo's
    Kalamazoo, MI
    Wow, that's looking really great!
    That looks like a piece of art. :D
  17. thecableguy
    Cleaned up the headstock binding.
    Glued on the fretboard.
  18. thecableguy
    Thanks Rick!
    Thank you!
    Thanks Lisa!
  19. mrz80
    mrz80 Tele-Meister Silver Supporter
    Gainesville,FL
    This is looking really good. Nice job!
  20. thecableguy
    Made a neck pocket template. Not doing the standard Gibson mortise and tenon joint.
