LP Jr DC type thing
Discussion in 'Tele Home Depot' started by CraigB, Dec 26, 2018.
  1. CraigB
    CraigB Tele-Afflicted
    Central Coast of CA
    Hope ya'll had wonderful Christmas festivities with family and friends! It's hard to believe that 2018 is soon coming to a close. Been spending quite a bit of time playing (unplugged, unfortunately) the kit LP goldtop I started building earlier in the year. It turned out quite nice, and looking forward to doing some recording with it when the decorations come down and I can get my recording area back in shape. Will post some sounds when that happens.
    Pretty decent weather today, so seemed like a good time to move the work table outside and resume work on the LP Jr build. Here is where I left off with the body blank planed, cut and flush trimmed to shape.
    And the 4-piece neck blank laminated, side profile rough-cut, and fretboard gluing surface and headstock surface trued up
    Here's what the end-grain looks like
    Started today with my manual thickness sander (which also doubles as a tricep fitness machine) truing the top and back. When I ran the the body blank through the planer, I intentionally left it about 1/16" proud of 1-3/4" thick, having been left with some tiny spots of snipe to sand down to, as well as a little hump near the tail to sand flat from the feed table not being perfectly adjusted.
    The top wasn't too bad, about 30 minutes of sanding got it nice and flat
    The back on the other hand was slightly cupped and took quite a bit more effort to flatten. You can see the planer marks and freshly sanded outer edges in this shot
    Eventually, was able to get the marks out, but I'm left with about 1/32" shy of 1-3/4" thick. Seems like a pretty minor discrepancy, so not something worth worrying over, right?
    Thankfully realized before starting to cut the trussrod channel that the [email protected]$$ plastic fence that comes with these tables is literally unusable, so with a makeshift fence clamped on, made a bunch of shallow passes with a spiral straight bit for the trussrod channel. I was planning to do the trussrod access like Freeman does it using the same bit, moving the position of the fence a tiny bit to widen either side of the channel to accommodate the adjustment nut, then remembered a 3/8" core box bit might work to avoid having to move the fence around. Not bad, not bad at all. And the potential for a big old screw-up was greatly reduced
    Being a novice at best, your input is always greatly appreciated. One of the things I've never liked about the traditional Gibby headstock is the lack of clearance of the A string passing the E string tuner on the bass side and same with the B and E on the treble side. I drew this headstock as a tentative design to try and position the tuning posts at a slightly different angle. And then the top, I like the classic "open book" cut, but what do ya'll think of this offset sort of cut?
    And that's it for today!
    Flakey, zippofan, nickhofen and 17 others like this.
  2. ndcaster
    ndcaster Poster Extraordinaire
    Indiana
    elegant
    Flakey and CraigB like this.
  3. BluesBlooded
    BluesBlooded Friend of Leo's
    Sherbrooke, Qc, Canada
    Looking great Craig. Love the headstock change.
    fenderchamp and CraigB like this.
  4. Jupiter
    Jupiter Telefied Ad Free Member
    Osaka, Japan
    Nice, and yeah, a little thinner body is fine. I often make em a bit thinner on purpose for weight reduction.
  5. oldrebel
    oldrebel Friend of Leo's
    Lynchburg Tennessee
    I really like the looks of the offset headstock. I think that it will look great.
    Flakey, fenderchamp and CraigB like this.
  6. soggybag
    soggybag Tele-Meister
    san francisco
    I like the headstock also. The lines are not over exaggerated.
  7. GotTheSilver
    GotTheSilver Tele-Meister
    Houston, TX
    That is the Collings "haircut" shape! I have always liked it.
    Slowisfast likes this.
  8. bender66
    on my bike
    Got that off center thing going on. Looks good.
    CraigB and 2blue2 like this.
  9. Danjabellza
    Danjabellza Friend of Leo's
    Pahrump, nv
    The double cut jr is one of the sexiest guitar shapes IMO! I love it!
    richiek65, CraigB and Bella like this.
  10. Jupiter
    Osaka, Japan
    that sharp notch in the HS looks cool, but it's kind of a pita to shape/sand/finish just sayin
  11. CraigB
    Central Coast of CA
    Ahhh, you're right, that does look a fair bit like a Collings headstock. Darn, that is just too close...and I was really starting to like how it looks...well, back to the drawing board!
    Very true. What do you think of trying to come up with a variation of something like this one I did a couple years ago, except a little longer and slightly wider at the top?
    I'm also trying to decide for the body, binding on the top, roundover on the back? Or just roundover on both sides?
    SecretSquirrel, Barncaster and 2blue2 like this.
  12. GotTheSilver
    Houston, TX
    Sorry, didn't mean to ruin it for you! It is extremely difficult to come up with a new headstock design that actually looks good.
    2blue2 and CraigB like this.
  13. GotTheSilver
    Houston, TX
    I love LP Juniors! My last two builds have been Juniors. The first one I dressed up like a Les Paul Custom, so I did 7 ply binding on the top and 5 ply on the back. I still need to paint that one black (insert Rolling Stones song here). The one I am currently building will be blue. I am doing 3 ply binding on the top and a roundover on the back. Of course, now that I think about it, maybe I should do single ply binding on the back!
    Obviously, I like binding!
  14. CraigB
    Central Coast of CA
    No, I'm very glad you caught that!
  15. adirondak5
    adirondak5 Wood Hoarder Extraordinaire
    Long Island NY
    That headstock design looks great Craig !
  16. Freeman Keller
    That's a great tip - I'll remember it.
  17. 2blue2
    2blue2 Friend of Leo's
    Island of Oahu
    No its not , I like your shape, the Agile curves out and your curves go in.
    Well if your not going to use it...
  18. CraigB
    Central Coast of CA
    Thanks 2blue2! I was referring to GotTheSilver's post, he points out that it looks like a Collings headstock. I think he's right. I thought I came up with something original, but really comparing the two the only difference on mine is the placement of the notch and how it kind of rolls into about a 45 degree angle, and mine is wider at the top. Scroll down this page and check it out:
    https://www.collingsguitars.com/electric-guitars/290-dc-s/#&gid=1&pid=7
    2blue2 likes this.
  19. Slowisfast
    Slowisfast Tele-Meister
    Mt. Rainier
    Def has that Collings look albeit flipped. Looks great!
    CraigB likes this.
  20. RickyRicardo
    RickyRicardo Friend of Leo's
    Calgary, Alberta
    I'd still go for it. It looks great.
    CraigB and BluesBlooded like this.
