Lower gain on rat, without losing its "sound"
Discussion in 'The Stomp Box' started by bluesholyman, May 18, 2017.
  1. bluesholyman
    bluesholyman Tele-Afflicted
    Greater Atlanta
    Is it possible? I know I am playing with perfection here, but any one do this, attempt this, have a good sounding mod to recommend?
  2. doctor_capleson
    doctor_capleson Tele-Meister
    Minneapolis, Minnesota
    Is simply using less gain from the pedal not an option? Not asking sarcastically, I guess I don't understand the question fully.
  3. RetroTeleRod
    RetroTeleRod Poster Extraordinaire
    Oklahoma, USA
    Keith over at Machine Head Pedals can mod it for you. He put a lower gain pot in my WF Rat Re-issue. You will broaden the lower gain range of the pedal, at the expense of losing some of the "fuzzy" portion at the upper reaches of the drive knob. If the area from 3 o'clock and up on the Distortion knob is too much for you then you might be a contender for such a mod.
    bluesholyman likes this.
  4. artdecade
    artdecade Poster Extraordinaire
    Twangsylvania 6-5000
    Rat 2? Turbo Rat? Fat Rat? You Dirty Rat?
    Maybe you have the wrong Rat for the job. Maybe the Deucetone is in your future...
  5. stringslinger
    stringslinger Tele-Holic
    Nashville, TN
    I used to have my Rat as the lower gain OD pedal. I was really into Scofield, and he used (or still does use) a Rat for that slight "bitey" overdriven tone.
    Low gain (talking 8/9 o'clock) with higher volume on the pedal worked for me back then.
    Agitator likes this.
  6. Redvers
    Redvers Tele-Meister
    Wales
    Low gain IS the rat sound. But yeah lowering the gain pot would give you more tweak ability. Think carefully about the pot though, I think it's 100k log. Basically if you put in 50k log you might actually find there's no difference because 9,10 o clock on the pot still gives you a very small value. (Although the Max gain will be halved ). 50k lin is probably is good starting point.
  7. Agitator
    Agitator Friend of Leo's
    In transit
    This. I've done the same thing, for the same reason. :D
  8. MilwMark
    near Arnold's
    I think a 10k pot works great actually.
    But the thing is, to my ear as you turn up the distortion you get two things (I mean, in addition to more clipping):
    1. Highs are cut
    2. More compression. A lot more compression.
    You can compensate for 1. with the Filter. Don't be afraid to turn it fully CW if you are using the Dist really low.
    You can't really get 2. though (that I know of). And the Distortion pot mod (which is great) doesn't supply it. It just spreads the low gain sounds over a wider distance so you can dial them in more precisely.
    So off the top of my head, I'd put a compressor pedal before the Rat if what you are missing is the compression that is present in the higher Distortion settings.
    I could be way off base, as I'm a player, not a tech. But this is what I hear and feel.
    Curious if @11 Gauge, @cousinpaul or @waparker4 or other folks who like to poke around in circuits have some thoughts.
  9. waparker4
    Philadelphia, PA
    Part of the "Rat sound" is pushing that op amp to its limits, generating op amp distortion. So you kinda have to be at that minimum level of gain to get that going on, I guess.
  10. bluesholyman
    Greater Atlanta
    I have chatted with Keith before, incredibly knowledgeable - that could be an option...
    RetroTeleRod likes this.
  11. RetroTeleRod
    Oklahoma, USA
    Keith is great! In addition to swapping in a 50k pot for the Distortion knob, he also added LEDs to the inside of my WF Re-issue that shine through the sides of the pedal (because they have no status light) He does quality work at a reasonable price.
  12. luckett
    luckett Banned
    I'll second a 10k, or even a 5k. The resistance is very low when the pot is at 9:00. Somewhere in the 1k-2k range IIRC.
    For point 2, you just need to swap out the diodes for your needs. Germanium or rectifier diodes like a 1N60 for more compression. LEDs or more silicon diodes in series for less compression.
  13. allesz
    allesz Tele-Meister
    Italy - Bologna
    Don't spend a lot of money: solder a 22k 1/4 watt resistor across the outer gain's pot lugs.
    Done.
    The taper of the pot will be altered, of course, but you can test the "gain zone" with a mod easy to undo for just 0,10 Euro.
    My 0,10 Euros :)
    waparker4 likes this.
  14. SamClemons
    SamClemons Poster Extraordinaire
    Jasper, TN
    Ha! Never could bond with a Rat. Not enough gain. Maybe you are really looking for something else like a good boost pedal like EH or Xotic
  15. bluesholyman
    Greater Atlanta
    Well the Rat is immensely versatile, if I mod one to be on my board, it will sit next to an un-modded one.
    Never saw the day coming that I'd love the Rat...
    aerhed and RetroTeleRod like this.
  16. ICTRock
    ICTRock Tele-Afflicted
    Tampa,FL
    playing with the feedback loop filters is a place to start. use the amz rc filter calculator and start with the 47R/2.2u filter to a 470R/.22u.
  17. Hollandcaster
    Hollandcaster Tele-Holic
    Wagenberg, Holland
    I bought a bigbox Rat (reisseu 90's), less gain but fatter in sound.[​IMG]
  18. Redvers
    Wales
    Good idea. Putting resistors in parallel will also make a log pot slightly more linear so this is a doubly good mod. Wouldn't it be a central lug and an outer lug though?
  19. songtalk
    songtalk Friend of Leo's
    Greensboro, North Carolin
    Dude, the RAT not only sounds good with the distortion knob all the way down, it's actually still got plenty of grit.
    Try bringing it all the way down and then inching it up to where you want the maximum clipping. Season with filter to taste. Volume at or slightly above or a good bit above unity to taste.
  20. bluesholyman
    Greater Atlanta
    This clearly points to a board with two rats on it...
    RetroTeleRod and songtalk like this.
