Cali Dude
Cool rig!I agree, my gremlin works with everything and I run a Strymon Flint in front for trem & verb. I run a super overdrive through it as well and is much more flexible than my other low wattage combos.
Why not the Ultra?I'll suggest the VHT Special 6, but the base model, not the Ultra. It is a 6 watt all tube beast that is Hiwatt clean at lower gain settings and is reminiscent of mid-late '60s Marshalls when cranked. However, if you are playing at bedroom levels there is no way in hell that you will EVER reach any noticeable tube saturation without using a power attenuator. They take pedals great. They are relatively lightweight and have a VHT branded 10" speaker that is surprisingly efficient, albeit bassy like most 10" speakers are for guitar. The Special 6 is quite fond of pedals and is a really good jazz amp as is. They are modder faves, but honestly, mine sounds so good I haven't changed anything. If I could, I would put the chassis in a pine Tweed style cabinet with a 12" speaker. I think it would make this combo even better. If you used a neodynium speaker it would lighten the weight to at or below 30 lbs. The stock cabinet is MDF and the speaker has a substantial magnet for a 10", so it is surprisingly heavy for a small combo. I didn't want to like this Chinese made amp, but it is top notch in build quality and its sound. It's worth a look.
Why not the Ult
Because the base model is cleaner, lower gain, and at least a marginally more pedal friendly version. There's nothing wrong with the Ultra, it just seemed less appropriate for the listed attributes. The straight Special 6 is one of the cleanest tube amps I've ever heard, and remains so unless you dime it with the boost engaged.Why not the Ultra?
I gigged the 20W Hurricane for a few years. Wonderful top quality, great sounding amps and it's a shame that Cornford are no more. My small amp now is a slightly modded (speaker upgrade), Marshall DSL5CR. Fine little amp, but the stock Celestion Ten-30 isn't really good enough. My smallest amp is a 2W Hayden Lil' MoFo, 1x8, and perfect for the home and intimate gigs.If you're looking for a tube amp you're looking for one rated at 6 watt or less. My Cornford Carrera is perfect for this use but I'm sure there are other less expensive amps out there that will work just as well.
