Low Gain Overdrive for a Jazzy Tone
Discussion in 'The Stomp Box' started by OwenHu99, Jan 11, 2018.
  1. OwenHu99
    OwenHu99 TDPRI Member
    Toronto, CA
    Recently Ive been obssessed with Julian Lage and his tele tone. I'm running a MIM tele into a very slightly driven Blues Junior with an attenuator (volume 5, master 4). But with my amp and a boss bd2, I just cant quite achieve Julian's almost fuzzy small tweed amp cranked compression sound that is extremely dynamic and very expressive when you dig in. I currently have the Walrus Audio Messner in mind after seeing Reverb's demo of it on Youtube. What are some other choices? Thanks a bunch in advance!
  2. -Hawk-
    -Hawk- Friend of Leo's Silver Supporter
    IL, USA
    Catalinbread Formula 55 has a big range of low gain sounds in it. Voiced pretty dark.
    Might look at some of the Lovepedal offerings too - there's a Champ pedal (among others).
    tele-bastard likes this.
  3. -Hawk-
    IL, USA
    I did go through this same pursuit last year by the way and you describe what I was looking for quite well.
    One thing I found useful was using the bridge pickup with the tone rolled off a ways. That may get you close with your current set up. Another surprisingly easy way to get in the ballpark was using a 57 Deluxe model on the Fender Mustang (that I tweaked to my liking).
    El Tele Lobo, songtalk and OwenHu99 like this.
  4. Doghouse_Riley
    Doghouse_Riley Tele-Afflicted
    L.A.
    The ZenDrive gets that cool Robben Ford like jazzy/bluesy edge-of-breakup tone.
  5. OwenHu99
    Toronto, CA
    great! forgot about the catalinbread, will check it out again to refresh my memory, thanks
  6. GuitOp81
    GuitOp81 Tele-Holic
    NJ
  7. -Hawk-
    IL, USA
    I made this after I got the F55. It's just a few low gain sounds from music I was working on at the time. Not really Lage'ish, but maybe it'll be of some use to you.
    There is also a demo of it using a looper online. It's long and boring, but useful if you're interested.
    KyAnne, Theorage and nhsdpl like this.
  8. JD0x0
    JD0x0 Poster Extraordinaire
    New York
    I like the warm, woody tone that you get from a Dumble style OD for jazz. It's a very 'polite' sort of overdrive and sits in the jazz mix well, IMO.
    Ben-Zion, KyAnne, Theorage and 3 others like this.
  9. Doghouse_Riley
    L.A.
    ^^^Yup, that's why I recommended the ZenDrive which is a "Dumble-in-a-box" pedal.
    Guitaryellow and viccortes285 like this.
  10. Danjabellza
    Danjabellza Friend of Leo's
    Pahrump, nv
    The me drive comes to mind for me.
  11. OwenHu99
    Toronto, CA
    Zendrive is a good shout, but from memory, it isnt exactly what im looking for. However much I love Larry Carlton and Robben Ford, under the current circumstances, Im seeking after Julian Lage's tele jazz tone. Watch his trio live at the blue whale performing I'll Be Seeing You and you will understand :)
    El Tele Lobo and raysachs like this.
  12. JD0x0
    New York
    I'd still recommend a d style pedal (or amp) for that sound. That sounds a lot like my ODS with the PAB engaged (tonestack bypass-gives midrangy flat EQ with a gain boost)
    The sound is 'almost' clean. Very small amount of clipping. You'll probably find even with a 'Low gain' pedal you're going to need to set the gain/drive below 9:00 for that type of sound.
    Also, remember that the D style tone is a lot wider than just Larry Carlton and Robben Ford's type sounds.
    What's Julian use? Sounds like he may not be using pedals, and is getting that mostly from the amp, but I could be wrong.
    El Tele Lobo likes this.
  13. OwenHu99
    Toronto, CA
    he uses an old tweed champ without pedals, so the catalinbread formula 55 suggested above seems good
  14. Televised
    Televised Friend of Leo's
    Portland, OR
    Friend of mine has a J. Rockett "Blue Note" and is very satisfied with it:
    Also, J. Rockett makes, "The Dude" pedal which is another Dumble in a box.
  15. Sooper8
    Sooper8 Tele-Holic
    UK- Midlands
  16. Vladimir
    Vladimir Friend of Leo's
    Zagreb, Croatia
    I'd recommend the Rat for low gain jazz overdrive
    snottyboy and tele-bastard like this.
  17. Troubleandahalf
    Troubleandahalf Tele-Holic
    Austin, TX
    I got a Mojo mojo for cheaps recently. Very "mellow" od
    darkwaters and tele-bastard like this.
  18. dlew919
    dlew919 Poster Extraordinaire
    Sydney
    I was going to say a blues driver, but I’m wondering if a soul food or even a lpb-1 boost might do it for you?
  19. dlew919
    Sydney
    Overdrive for some people means rat. (It’s ok, I usually default to blues driver ;) )
  20. Troubleandahalf
    Austin, TX
    Else EMG pickup retrofit indicated for warm jazz understatement.
    dlew919 likes this.
