Svoga_____
Hey, it's been some month since i bought a new guitar, but i now have a issue with the low e string.
At first i had nothing to say about the instrument, but when i changed from 10 gauge to 9, the low e string started buzzing hard, since the original nut was poorly cutted, i changed it thinking it would resolve this. This morning, i tried to tune it, and the exact same buzzing was there...
So, it's clear it's not the nut to me, i adjusted it and the string is just a bit higher when on the fret one when i push on the third, surely not the neck that seems to need no adjustement. I also mounted the sadle the higher possible and checked the frets hight, the string sit always higher than the frets after so it's not that for me.
The buzz is there when i play the open string and from the first to the 7-8 frets and it's totally gone on the 10 and after.
I dont have much more idea about this issue, maybe the sadle is the problem and should be fixed but i dont know how to determine it or fix it. Also this guitar have a "floating tremolo" i dont know if there is another name for it but you can see it on the guitar here. The tremolo was 2-3 mm higher than the body and now the end touch it when in neutral position, but how could it cause this issue and only after lowering the gauge ? And last but least likely, this particular string is poorly made and i should juste change it with a new one.
Thanks for reading this, i hope someone have better ideas than me or i'm just gonna take it to a professional luthier.
