LOUD buzzing when I turn on my Overdrives
black_doug
North of Toronto, Ontario, Canada
I was using a splitter for 2 of my overdrives, and had noise issues there too. My EB Volume/Tuner pedal was running off it’s own dedicated tap on the Zuma. As soon as I pulled the volume/tuner from the chain the buzz stopped. I think there is something that the active component in the pedal, possibly the touch screen power grid, that causes problems. Oh well. I was using it as a volume pedal only because the tuner function is… terrible.
I have the EB Jr and never had a problem like that. It’s not active.
gwmullins
Alpena, MI
I know this discussion is primarily about the pedal board, but the OP also mentioned buzzing/hum from his ‘75 Princeton Reverb amp. It’s likely the AA1164 circuit and there is a grounding issue with the layout. The RCA jacks for the reverb and tremolo are not properly grounded using the stock chassis ground. They all buzz/hum unacceptably with reverb set above 3. There is a fix (I’ve done to mine).
Replace the standard RCA jacks with insulated RCA jacks and run a ground wire from the insulated RCA jacks to a ground on the eyelet board. There are only a few ground eyelets on the board and some are better than others. Find the right one and the reverb hum goes away, even set on 10.
Hope this helps,
Greg
abcsoundguy
Idyllwild, Ca.
What does the 1M pot do?
I looked at it like a guitar volume pot, because adding a volume pedal is like adding ANOTHER 250k ( Strats, Teles) volume pot, so replacing the stock 250k pot inside the passive old Ernie Ball Vol pedal, with a 1meg, there was SUBSTANTIALLY LESS treble loss, aka tone suck. It really works, for a cheap fix. I just made the $jump to active, for the buffer, and available boost, but I kept the old full size 14 shoes EB pedal ( with the 1 meg in it ), for backup.
JuneauMike
Alaska
Cool. What pot did you use to replace it? I've seen pots with super long posts before. Is it one of those?
GPoint
My Tele or LP straight into my PR sounds pretty awesome! But at church I need a couple overdrives, an “ambient” reverb, delay and volume pedal (for swells) at the minimum. I could take the 808 or Clone and the Rat off the board and be fine, but the 808 and Clone sound SO good when stacked. And the Rat… it’s a Rat!
But I agree, less is more. I have a couple friends who have pretty large boards because they are playing at churches that “play it like the album” so they have to have a lot of options. My church, we play it as best we can without being a distraction.
Move your gears to the side, if it helps/changes noise - check what is going on under the floor. Maybe there is something like an AC transformer or something else radiating noise.
abcsoundguy
Idyllwild, Ca.
I wish I knew, as the 1meg pot was installed by a tech friend, not by me. Since this tech is primarily a guitar ( not pedal ) tech, I'm assuming he used what he had handy, which would be likely a CTS common 1meg Vol. pot for a guitar. Sorry I can't be of more help.
Alex_C
Straight in first. Does it buzz?
Yes - check cable, check guitar, check amp, change ac outlet to another location.
No - add a single OD to the chain, repeat the procedure of checking all added components.
Usually it is cables. imo.
New Posts
