I need some help from the collected knowledge here on TDPRI.
I’ve started playing at my church, and the first practice there was a noticable buzz coming from my rig; Tele or Les Paul, buffered Volume, overdrives (3-4), trem, verb, delay into a ‘75 SFPR. Pedals are powered through a Strymon Zuma, power cables are strymon. I even bought mogami 2319 and squareplug jacks, but making my own cables didn’t fix the noise issue (I solder PCBs and build pedals, and I checked every cable with my multimeter so I wouldn’t think the cabling is the issue).
The buzzing got SIGNIFICANTLY louder when I hit any of my drive pedals. My Rat was unusable, and the buzz was loud enough that it was heard over everything, even with my Les Paul. The weirdest part was if I turn my amp’s reverb up past 4 buzzing starts coming from the amp that is unbearable. I’m sure the church has crummy power (old building), but I’ve never run into this problem before. I hear the buzzing when I play at home as well, though not as prominent as when I’m at church. The buzzing started fairly recently. Not sure where to even start looking.
So, for those of you understand these sorts of things, any ideas where I should start my search for the cause of the noise?
