Looking for SUPER SUPER CLEAN mods for Fender Super Reverb
Discussion in 'Amp Tech Center' started by Diverted, Oct 2, 2019.
  1. MilwMark
    near Arnold's
    I don't know. I'm not after super clean. Far from it.
    The magic of these is in the subversion of intent.
    There is breakup in a Super even at 3-4 when it sounds "clean". Take that away, the accompanying compression and the way frequencies get suppressed and then leap out? Is it still a Super?
    Might be a cool amp for someone. I don't know. But if clean is desired, grab a JC40 and be done. (It's own cool sound, in my book, FWIW).
  2. schmee
    schmee Poster Extraordinaire
    Cool.
    Yeah, I learned, (as a former disbeliever), that tranny size alone can make a huge difference. I took my hot rod Princeton back to stock Princeton a year or two ago. However the chassis had been hacked for the big PT and at the last minute I just left the Super power tranny in the amp. It absolutely floored me how much cleaner the Princeton was with that change. I have only been able to use a PR in very small clubs with limited low gain OD in front before. This thing stays fairly clean up more on the dial.
  3. muchxs
    muchxs Doctor of Teleocity
    New England
    I accidentally built a clean 5E3.
    There was one down at Crossroads Guitars I'd visit once a year. They usually had a cool amp or two down there. Year in and year out, that was one of them. They didn't sell it because it was overpriced. It was overpriced because they didn't want to sell it. They didn't want to sell it because it was a unicorn, a 5E3 that played clean.
    I figured I'd get a look under the hood some day. Since they moved out to Salt Lake... probably not.
    No worries. I built my own.
    Diverted likes this.
  4. tubejockey
    tubejockey Tele-Meister
    the bozone
    Don't forget to decouple the tremolo with a switch on the pot. Better fidelity.
  5. BobbyZ
    BobbyZ Doctor of Teleocity
    Snellman MN
    Still trying to wrap my brain around playing a Super Reverb full out.
    I've got two of them a '73 and a '66. Guy I bought the 66 from played it on 7. From experience I knew something was fishy because he lives in town with neighbors 50 feet on both sides.
    Back home the '66 on 10 is about as loud as the '73 on 3 or so. Still need to service that amp, been sitting in the corner a year now.
    Anyway if he played healthy Super Reverbs cranked, where did he play them? I'm in the country but have neighbors a quarter mile away that probably wouldn't like that.
    Something is wrong with his story, maybe he's using an attenuator or turns down the guitar volume? If he gigs where?
    And besides that the stock speakers in an old SR would blow in short order like that.
    Can he still hear? :)
  6. tubejockey
    the bozone
    Loud is really more a function of speaker efficiency than anything else.
  7. avspecialist
    avspecialist TDPRI Member
    avon,ct
    Actually tube jockey, tremolo disconnect gives you more gain, which can be taken as more fidelity. For some songs, I like the tremolo disconnect. I put a switchable pot on my tremolo on a 74 twin I am rebuilding.
    Wally likes this.
  8. avspecialist
    avon,ct
    Also, not actually a mod, you could slightly bias the amp slightly colder for cleaner sound. Too much coldness on the bias can make the amp lack harmonics and sound a little sterile. For amps you want to be cleaner longer, you could order a matched set of tubes that have a the least amount breakup. The current production tubes I really like are from “The Tube Store” their preferred series 6l6GC aver very similar to the RCA blackplates. I buy these a lot, since they are not too expensive and sound great in my Fender amps. I think they are just slightly nicer than the TAD 6L6GC. I didn’t care for their 6L6WGC for the super reverb, that was initially recommended.
  9. Diverted
    Diverted Tele-Meister
    Bristol RI
    I
    m thinking about a Heyboer with HV secondary 352-0-352@250ma. Enough?
    I wasn’t able to find reliable specs on what the current capacity on the original was. I saw anywhere from 200-250ma.
    I’ll be using solid state.
    Thanks! And yes I’m putting it in a Princeton chassis, may have a handle on a JBL E-120-8.
  10. Diverted
    Bristol RI
    The tremolo circuit is not going to be built
  11. Marquee Moon
    Marquee Moon Tele-Holic
    New Jersey
    yeah, maybe just get a twin. or build a twin that isnt a bf super reverb, if that is too loud.
  12. Diverted
    Bristol RI
    It would be simpler to build a straight Twin clone with traditional cab. But the whole thing here is what he wants, and it’s not a Twin. He wants as close as he can get to its clean, in a small amp he can manage alone.
    He wants:
    1. Twin reverb clean
    2. Super Reverb wattage
    3. Smaller Princeton-size cab with a single 12.
    I thought going with a Super Reverb AB763 circuit to start with was a good start. Just looking for suggestions on cleaning it up. Thanks though
    Marquee Moon likes this.
  13. Diverted
    Bristol RI
  14. David Barnett
    12AY7 tube on the front end. Lots of filtering. Big iron.
  15. 39martind18
    39martind18 Tele-Meister
    Spring TX
    Thought you said that weight was an issue! JBL E120-8s weigh in about 23 lb, tone to kill/die for but heavy as hell!
  16. Diverted
    Bristol RI
    Thanks. Can you school me a bit on this as it’s an area that I haven’t delved into yet. Thanks,
    Ted
  17. Diverted
    Bristol RI
    Yeah, I know super heavy but in the smaller size maybe less awkward?
    I also have access last to an Eminence Classic Lead 80 that might do in a pinch if the JBL thing is too much. Supposedly very efficient and clean speaker.
  18. 39martind18
    Spring TX
    I bought an E120 on evilbay several years ago. I had a cabinet made for a PRRI I had, and installed the E120. Great sound, and with the Princeton chassis, the weight wasn't TOO bad, but the weight of the speaker created rattles in the cabinet. I took it out of that application, and put it in a Blues Deluxe Reissue. The 40 watt vs 15 watt input really opened up the sound of the E120,but I think the larger cabinet of the BDRI was a significant contributor as well.
    My main amp these days is a 1971 DR, modified to run 6l6s with a solid state rectifier, and 2x10 JBL D110Fs. I don't play quite as loud as your friend, but the clean factor of that DR is impressive. _526.JPG _527.JPG
  19. Diverted
    Bristol RI
    Thanks.
    I’ll be building the cab for this one too. I’m used to building 15w combo cabs in pine so I’ll do my best to beef this one up as much as possible.
    Pine ok? Or rigid/heavier like BB ply?
  20. 39martind18
    Spring TX
    Pine would save weight, the cab I had made was plywood, but the guy that built it talked a better game than he delivered. I suspect you'd do a better job of it. The problem was more baffle buzz that cabinet, so with the E120, making sure the baffle is REALLY secured to the cab. I finally had to resort to using weather stripping between the cabinet cleats and the baffle board- worked!
