Cool, let us know what values you prefer.
When you say red and green together, was that parallel or series? You connected both to the lugs, side by side? Or end to end?
This is pretty much what I'm after right now except positions 2 and 4 swapped around. Could you, or anyone tell me how? ThanksAs before, if you don't want the HOOP cap, replace with a wire. It acts on both position 2 & 4. Want different order, let me know.
Thank you that's very helpful of you. Looks like a very usable set of tones there. And you simply replace the .01 cap with a wire if you ever want a full OOP pos. 4 correct?This is modified a bit from the earlier diagram. As I point out later in this thread, that one was not really correct. It works, but there is no such thing as series HOOP. Instead, the cap is simply a mild bass cut.
This is what I suspect you would want: Series OOP, and Parallel HOOP. And the positions are swapped per your request.
Correct re the wire vs HOOP cap.Thank you that's very helpful of you. Looks like a very usable set of tones there. And you simply replace the .01 cap with a wire if you ever want a full OOP pos. 4 correct?
Also, is there any difference if you connect the .047 cap to the back of the tone pot vs the volume pot, as I've seen both and never understood it.
