Looking for an almost clean boost with no compression
Discussion in 'The Stomp Box' started by don, Sep 8, 2019.
  1. don
    don Tele-Meister
    raleigh, nc
    Just got back in the tele world with a Fender 50’s road worn and use a Princeton reverb amp but need some boost with a light open airy non compressed overdrive. I’ll be playing Americana music mostly. I’m a melodic lead player so no chicken pickin or LED Zeppelin leads needed. I like a full rich sound with just an edge of twang. The stock pickups sound great just need a pedal for the single notes. Thanks for any suggestions. Caveats are it must run on battery and in the $150 and under price range.
  2. Asmith
    Asmith Friend of Leo's
    East Yorkshire, England
    Electro harmonix lpb-1 would do the job.
    dlew919, gwjensen and jimilee like this.
  3. Guitarteach
    MXR Microamp..
    Buying today, I’d look at TC Spark Boost for the extra grit it can add
    Fiesta Red and uriah1 like this.
  4. lefty73
    lefty73 Tele-Afflicted
    As @Asmith said, the LBP-1 will do the job. I think the MXR Micro Amp might do the same as well, and it might be a touch cleaner. The LPB-1's I've played through seem to color the sound just a bit.
    It's possible the TC Electronic Spark might do the job, too, but I've never played through one of those.
  5. Ringo
    Ringo Poster Extraordinaire Silver Supporter
    Memphis TN
    Lots of great boost pedals out there, currently I’m using a Xotic Super Sweet which you can easily find used for $100 or less, it has external dip switches for lots of tonal options , I’ve been running it flat for just clean boost.
    frank a likes this.
  6. scelestus
    scelestus Tele-Meister
    Michigan
    I got a Spark Mini for this. It needs a power supply but doesn't color the tone at all. Maybe a regular Spark will work for you so you can run it on batteries.
    urbandefault and 41144 like this.
  7. Tele22
    Tele22 Tele-Meister
    Europe
    I’ve used the Boss LS-2.
    It works as a clean boost and does a bunch of other stuff as well.
    codamedia and Obsessed like this.
  8. ahiddentableau
    ahiddentableau Tele-Meister
    Middle of Nowhere
    I'll risk coming across as unhelpful and say that I'm not sure what you want is possible, and it's probably best to recognize the limits of your rig before you go down this particular rabbit hole.
    A pedal like a microamp or an LPB-1 would be about as close as you can get to what you described. Those circuits don't do much of anything other than to provide extra volume. It's worth a shot, and if it works for you you're off and running. From a practical perspective, it's probably worth trying, and it might be good enough to satisfy you.
    But the real problem is what that volume inevitably does to your amp: i.e. overdriving V1. Unless your regular amp settings are whisper quiet (i.e. you have headroom to spare--not bloody likely on a PR!) boosting the volume on the front end is always going to create compression. There's no just avoiding it. When you boost the front end of a Princeton Reverb beyond its (fairly meagre) clean headroom, you get compression and harmonic distortion. Period.
    So you might do better to look at things from another perspective. Such as: "what guitar and amp combo would give me a less compressed tone compared to what I've got now?"
    Which is basically another way to say that what you really want is a bigger amp (more headroom).
  9. Telefan65
    Telefan65 TDPRI Member
    Telecasterville
    The one I like is the MXR MC401 line boost/driver.You can get ultra clean. Up around +20db for solos or use it to Drive your effects for more dynamics and/or sensitivity.
  10. DavidP
    DavidP Friend of Leo's
    Vancouver BC, Canada
  11. scottser
    scottser Tele-Afflicted
    dublin
    Without sounding facetious, why don't you just set your amp volume a bit higher and use your guitar volume instead of a pedal?
  12. don
    don Tele-Meister
    raleigh, nc
    Lots of good suggestions - I guess I should add more info. I have headroom left on my amp and I do realize that a volume boost will create some distortion and compression which is why I seek a pedal that won’t add to that.
  13. don
    don Tele-Meister
    raleigh, nc
    I want a little character for the solos not just louder
  14. ahiddentableau
    Middle of Nowhere
    If you have headroom left any relatively uncoloured booster should do the job. But it also makes scottster's comment more cutting. If you've got headroom, why not use the guitar volume? Or if you don't want to use the guitar's knobs, why not just use a straight volume pedal?
  15. don
    don Tele-Meister
    raleigh, nc
    Again I’m looking for some character not just louder
  16. sonicsmitty
    sonicsmitty Tele-Holic
    Clarksville, TN
    The guitar volume knob suggestions sound good.
    I have not played one, so don't take this as an endorsement, but the Voodoo Labs Sparkle Drive concept sounds interesting. It allows you to blend the gain signal with your clean signal which should give you more control over how clean your sound is theoretically. I'm sure there are members who have had experience with one who could tell you more. I have been considering one too.
    Greggorios likes this.
  17. RoscoeElegante
    RoscoeElegante Friend of Leo's
    TooFarFromCanada
    Not AT ALL being a wiseguy here, as I respect your question and share your tastes. But for this, I keep finding that my guitar's volume knob is the best uncompressed, clean boost. Try playing with your amp louder than usual but leaving yourself a good 1/4 more oomph left on your guitar.
    I see now that others have suggested that, too. Again, not being snarky, but keeping your signal chain as unbusy as possible and having that knob right there makes sense. You can work on swells, you can ease off some notes then drive a run harder, etc., much easier with your fingers than by clicking a pedal on and off. There's a lot of musical fluidity inherent in even a Tele's bone-simple knobs.
    As also suggested, volume pedal would also give you a lot of musicality, since a click-on/click-off boost is indeed an either/or thing.
    Pedalwise, the boost functions on the ABY box that I use to play two amps--Radial's ToneBone--are my favorite. (Radial makes a wide variety of good boxes.) . The ToneBone gives you got several boost functions and layers, it's dead quiet, it doesn't compress, you can use it in front of just one amp, but using a second amp to really thicken and push your sound either steadily or at click-able points is a great approach. I have a couple of real rocky songs that I click on an Excelsior to push things atop the AC15, for example.
    So a +1 to a hiddentableau's suggestion above that you may want a mightier amp than your Princeton to ensure that you've got more headroom on tap when you pedal- or knob-boost your playing--with all due respect, of course, to how great a Princeton is.
  18. schmee
    MXR Micro Amp is clean and cheap. Cleanest I'm aware of. The Barber Gain Changer set at near 0 gain is clean and adds some grit adjustment for more money.
    As others mentioned, reserving the 9-10 on your guitar volume knob gets you a clean boost. (more volume and more treble) But that's a fine line to walk for balance with the venue or rest of the band.
  19. rangercaster
    portland, or
    Some would recommend an EQ pedal ...
    Worth a try IMO ...
    Telecastoff1, Obsessed and Asmith like this.
  20. don
    don Tele-Meister
    raleigh, nc
    In my past when I was playing guitar in a cover band the VL Sparkledrive and the Nobels OD-1 were my go to pedals. Then I started playing bass. Now a buddy wants to do old country and Americana and I’m the only electric guitar / no screaming solos but a lot of big open chords and arpeggios and some fills. I find the guitar sounds more open and full with the volume knob wide open or close to it so I really prefer a pedal as I like the tone and open ness of the guitar like it is
    Diagoras likes this.
