Looking for advice on an all-in-one with a lengthy looper.
Discussion in 'The Stomp Box' started by dotpc, May 4, 2018.
  1. dotpc
    dotpc TDPRI Member Silver Supporter
    Everett, WA
    I have been looking at a lot of all-in-one units, in no particular order:
    • Boss GT-1000 - 38 second looper
    • Fractal AX8 - 4 minute looper
    • Line 6 Helix (or Helix LT) - 1 minute looper (2 minutes at lower quality?!)
    • Mooer GE-200 - 52 second looper
    • Zoom G3n - 80 second looper
    For a bit of context, I play a decent amount of solo gigs (mostly Jazz). I usually sing through a tune and comp (looping from the beginning or just after an intro), then solo over the tune. Hence the need for several minutes of looping (4 minutes is the minimum time I would be comfortable with). My current setup is an RC-1 into various amps (Acoustic Image Corus, Quilter Tone Block 201 with a McQuen cabinet using a B&C 8NDL64, and others). This works great, but I would love to shorten setup time for when I am sharing the bill, playing open mics, or at venues with a PA. Hence the need for something that could handle tone and looping.
    It seems that the AX8 is the only choice in this arena, but I wanted to bring my dilemma to this wonderful community to see if I am missing any choices.
  2. jddub440
    jddub440 Tele-Holic
    Tacoma
    Maybe check out EHX's new 95000.
    dotpc likes this.
  3. dotpc
    Everett, WA
    Does it have any kind of modeling? Seems to just be a looper.
  4. WetBandit
    WetBandit Friend of Leo's
    Somewhere
    Doesn't the TC Nova have a Looper?
  5. Guitarteach
    Boss GT (or similar) but put the RC1 or an RC3 (my fave) in the fx loop of the multifx. Only add seconds to setup and you can mix best of both that way.
  6. Obsessed
    Montana
    Digitech Jamman Stereo Looper. Even has an XLR input port. It can play the looped parts into one amp and then your final loop into a different amp which is great for live applications. Has an interchangeable memory card for practically unlimited loop time.
  7. dotpc
    Everett, WA
    I cannot find any specs to indicate this ... does anyone know for sure?
  8. dotpc
    Everett, WA
    I appreciate the sentiment here, but having it all in one unit is a top priority for me.
  9. dotpc
    Everett, WA
    Does this have amp modeling?
  10. WetBandit
    Somewhere
    I just looked it up and from what I can tell there isn't a Looper function.
    My bad...:oops:
    dotpc likes this.
  11. Obsessed
    Montana
    No amp modeling, but with the stereo option of running separate amps, it does give you a very advantageous alternative. It also takes pedals very well, but then you need to run the amps clean.
    There is a battleship version (my description) of an 8 switch version of the JML2 that has some delay and perhaps other stuff. I forget what it is called, but dirt cheap on fleaBay and someone here swears by it.
    Yeah, okay, I'll go check the name.:rolleyes:
    dotpc likes this.
  12. Obsessed
    Montana
    It is called, the JMD JamMan Delay. Seems to only have delay as an additional effect and they have gone up in price since I last looked. Probably not worth it for your application.
    dotpc likes this.
  13. jddub440
    jddub440 Tele-Holic
    Tacoma
    Oh yeah, sorry I guess I didn't fully comprehend your OP.....good luck!
    dotpc likes this.
  14. DaveKS
    DaveKS Friend of Leo's
    KS
    Why not just get you a pedalboard if setup is the problem. Plug into input, output to pa, power into AC. Done.
    Obsessed likes this.
  15. dotpc
    Everett, WA
    A reasonable option, but I prefer the all-in-one route.
  16. W.L.Weller
    W.L.Weller Tele-Holic
    Queens
  17. brookdalebill
    Austin, Tx
    Perhaps the EH Grand Canyon?
  18. W.L.Weller
    Queens
    The EHX Grand Canyon is only a looper though. @dotpc is looking to have one thing that does everything, if I understand correctly.
  19. phaedrus
    phaedrus Tele-Meister
    Austin, Texas
    Headrush or the Mooer GE300 should cover you.
    Of course, they do cost a bit more than the others.
  20. 4pickupguy
    4pickupguy Doctor of Teleocity Silver Supporter
    Fort Worth, Texas
    The new Flashback II x4 has a 40+ second looper. The four foot switches become live edit functions while in looper mode. Would make a great performance looper. Nice delay too.
    WetBandit likes this.
