How keen are you?
For the pre-amp section, there are lots of fairly low voltage examples out there that use valves. Not starved plate exactly, but they're hungry. You can use 6j1 or 6k4 pentodes in triode-strapped mode quite comfortably around ~100V They'll run in pentode mode at that voltage too, but you may not like the clipping.
There are IC amps operating in Class AB/AB1 from the simple ( and really quite awesome ) TDA2030/2050, which will give ~10 Watts/25 Watts reliably clean and 20/40 Watts with tuneful clipping, up to some real beasts with the TDA7294. The 7294 and its ilk have powered many an amp. Heatsink the daylights out of it though, unlike Marshall with the original MG100DFX... CPU heatsinks and fans aint enough. Chip go phut!
https://www.electroschematics.com/tda-amplifier-circuits/#tda7294
If you get really keen, Velleman and Maplin used to make discrete FET amps that'd happily push 100 Watts clean into an 8 Ohm load. get the sound from the pre-amp and use the power stage to lift it, but the old, discrete FET amps sounded quite good as they were. I used to clone a Maplin FET amp board that'd happily push 160 Watts @ 10% into 4 Ohms for installation and PA purposes. You need a 60-0-60 or 80-0-80 for them though, which gets close to valve transformer costs. One of my old bass amps was powered that way. It rocked. The schematics are readily available.
Use the whuftiest toroidal transformer you can for the required voltages. An inductor after the rectifier, before the smoothing caps, is your friend.
AB chips, such as the TDA sound quite good at the onset of clipping. FET stages sound really good. A FET stage into a 1:1 transformer?, magic happens at high volumes as the transformer saturates naturally, just like a valve stage
Valve or valve/FET ( even an op-amp or two for the tone stack ) for the initial stages, AB chip amp or FET for the power stage. Class D is -ok- until it clips. Then it sucks.
Have a look at the schematics for Marshall/Park solid state amps for a good starting point.
