Looking for a pedal to add "thickness"
Discussion in 'The Stomp Box' started by Fuzzblaster, Jul 1, 2012.
  1. fezz parka
    fezz parka ---------------------------
    Del Floria's Tailor Shop
    A wiggle box with the rate at it's lowest setting adds thickness. Adjust depth to taste.
  2. artdecade
    artdecade Poster Extraordinaire
    Boggo Road
    Get a delay and set it for about a 23 ms delay... Works for me.
  3. Jagg76
    Jagg76 Tele-Holic
    TELE-tropolis, Canada >;-)
    +1 on the RC Booster. I don't own one but I've tried one and I was hooked! :eek:
  4. B.G.L.
    B.G.L. Tele-Meister
    Springfield, MO
    Keeping with the theme of easy on the wallet, there's always the Bad Monkey. Subtle dirt with nice tonal options. I love my TS9 with the pushed mids, but the BM does the slight boost thing really well. The two-knob EQ makes it quite versatile. You can mimic the EQ curve of your amp, but just dial in some oomph from the BM. Or add a little hair to your tone. Pretty cool and dirt-cheap new, like $39.95.
  5. Larry F
    Iowa City, IA
    I use a Zendrive 2 or a Fuchs Plush to do just that. They are worth the price in my book. I haven't used a boost per se, but I am getting more and more interested in trying one, although it might be unnecessary if I always leave the OD on.
  6. Larry F
    Iowa City, IA
    Yeah, and a delay. I always have one of those on, too. Just so it is not noticeable as a delay.
  7. Larry F
    Iowa City, IA
    Yeah, and a Bad Monkey. Why am I parroting what others are saying? But it is true, the Bad Monkey does an incredible job for the price. OK, I'll stop.
  8. EasyEB
    EasyEB Tele-Meister
    Arlington, TX
    I am surprised nobody has mentioned the Catalinbread SFT.
  9. Pants
    Pants Tele-Meister
    Austin
    As a fellow AC30 user, I have to say... I'd stay away from the EP Booster for fat sounds. With my Vox, it makes everything sound a lot sharper- it has a ton of upper-mid "kerrang" to it, which is cool, but probably not what you're looking for.
    Instead, I STRONGLY recommend a Red Llama. I think you'll love it- you can keep the gain down and pump up the level to really goose your amp's front end. You'll find some excellent grainy sounds in there with a really full, resonant bass character. As far as ODs go for a Vox, I think the Llama is one of the best. Match made in heaven, and we all know how temperamental that amp is when it comes to drive pedals...
  10. Fuzzblaster
    Fuzzblaster Tele-Meister
    Kelowna, BC
    What I am looking for is a pedal to take my already slightly overdriven signal, and add a bit more gain, beef it up a little so it sounds a bit more present and less "thin" so to speak. Trying to make some gravy with my Vox, thicken er up! Fatter/chunkier rhythm and slightly more sustained, present, and well-rounded single-notes. This would be for mainly live stuff to go from a chimey/sparkly overdriven sound to a slightly more round/fat overdriven sound with a bit more gain. I know trying to get my idea across using jargon isn't the best idea, but its all I got!
  11. fuzzbox
    fuzzbox Tele-Meister
    Atlanta
    My RC Booster does precisely what you describe. Quality build and very reliable. One of my "must have" pedals.
  12. telerocker1988
    telerocker1988 Tele-Afflicted
    Illinois
    EP Booster. As I just posted in another thread, the RC excels at transparent clean boosting and the EP is the best thing I've found for fattening up single coils and adding natural sounding warmth. It's based on the Echoplex preamp and very warm and natural. I use both on my board but for your purpose I find the EP to be much better and what that pedal does best.
  13. Fuzzblaster
    Kelowna, BC
    So it seems that the boosters are getting the most love on this thread, the Xotic lineup in particular. Which do you think would work best with my AC30, for the tone I described above?:
    EP Booster
    AC Booster
    RC Booster
    Fulltone Fat Boost
    BBE Boosta Grande
    or something else...
    Thanks for all the suggestions guys, keep em coming! :D
  14. Pants
    Pants Tele-Meister
    Austin
    Again, speaking from my experience with my gear, I don't think the EP booster is quite the ticket for thickening up a Vox on the edge of breakup. Too much kerrang; not enough thump. Lots of people here dig it, and it really is a cool pedal, but as you and every other AC30 owner know, that amp is picky as heck when it comes to drive pedals, and not every shade of drive that works for the Fender amp-playing majority here is going to cut it with an AC30.
    I'm not familiar with the other Xotic pedals, but I did hear that the AC Booster is patterned after the breakup on an AC30. I still say Red Llama.
  15. Fuzzblaster
    Kelowna, BC
    The only thing I'm afraid of with the Llama is that I already run my amp with a good amount of overdrive (not on the verge of breakup, it is breaking-up), and I think the Llama may cascade it to be a bit too "gainy" (just looking up some videos on the tube), not sure if my suspicions are true at all, do you have any audio clips or anything like that?
  16. Fuzzblaster
    Kelowna, BC
    + The gain structure of the pedal sounds really fizzy to me, fizzier then my Boss BD-2 that I am currently running...
  17. LawDaddy
    LawDaddy Tele-Holic
    Auburn, CA
    Interesting thread. I play into a solid state amp often, and use a Tech21 Blonde to accomplish the same thing. I set it for a very clean sound/character, and run the output above unity gain. Adjust the highs to suit the room, bingo, thicker tone. It has a bit of natural compression and responds very naturally to the volume knob.
  18. Fuzzblaster
    Kelowna, BC
    I found my answer in the TC Electronics "Spark Booster" just the right options, and sounded right in the videos I found as well! Putting in my order in the morning.
  19. TeleToTheRain
    TeleToTheRain Tele-Holic
    in a van by the river
    Thank you! I think I'm crazy sometimes for really liking this pedal... I mean, all things point to "no" right?... cheesey look, name, price tag, yet, I can't stay away from it, it really sounds great!
  20. Pants
    Pants Tele-Meister
    Austin
    Solid choice! Yeah if "fizz" isn't a desirable characteristic the Llama definitely might not be the right pedal... it's not as fizzy in real life through a slightly driven Vox as it is on Youtube through all those Fenders, but it's still there. Sounds like the Spark Booster would work a lot better.
