Looking for a bridge
Discussion in 'Other T-Types and Partscasters' started by Eric Smith, Sep 29, 2020.
  1. Eric Smith
    Eric Smith Tele-Meister
    Plymouth, IN
    I'm building a parts caster and the body that I have is routed for hum buckers. I'm wanting to put a single coil in the bridge but single coil bridges aren't wide enough for to cover the route. Does someone make a bridge that will cover the humbucker route?
  2. sleazy pot pie
    sleazy pot pie Tele-Afflicted Gold Supporter
    austin
    They have bridges that are two pieces.
    One is a tele half bridge and the other is an adapter plate (pickup ring) that holds a single coil tele bridge.
    I don’t know if the holes would line up with what you already have though.
    But that isn’t a huge deal.
  3. kookaburra
    kookaburra Tele-Afflicted
    Phoenix, AZ, USA
    Where's that confounded bridge?
    Veitchy likes this.
  4. Eric Smith
    Plymouth, IN
    So it's basically a pickup ring? I am actually trying to avoid the pickup ring look. I was hoping that it would be more of a Hot Rod look.
  5. Telenator
    Vermont
    [​IMG] Can you install this and make an insert to set the bridge pickup in?
  6. sleazy pot pie
    austin
    this is what I am talking about
    Two Jays likes this.
  7. Eric Smith
    Plymouth, IN
    How does that mount to the bridge though?
  8. Leonardocoate
    Leonardocoate Tele-Meister
    Ohio
    You can use your existing bridge and put the single coil pick up in a Humbucker cover. You just need to use a cover that matches the pole spacing....2-1/16" is pretty common...I have done it several times. I have a single coil pu in a P90 cover....works great
  9. Peegoo
    Peegoo Poster Extraordinaire
    Yonder
    That's a Gotoh brand.
    Make sure you get the correct bridge for the body you have. Some modern bodies are drilled for string-through differently than older Tele bodies.
    kookaburra and sleazy pot pie like this.
