Locking tuners
Discussion in 'Squier Tele Forum' started by Pantonelli, May 30, 2019.
  1. Pantonelli
    Pantonelli TDPRI Member
    Quartz Hill, CA
    ok, I’m sure that this has been asked a ton of times.
    Do the Fender brand of tuning machines just drop in on a squire, or do I need to drill two little holes, on each tuning machine?
  2. vanr
    vanr Tele-Afflicted
    AZ
    Some Squiers have the 2 little tabs that fit in the holes, but they are not in the same place as the Fender 2- tab tuners. I had to drill 12 holes when I put Fender locking tuners on my Squier. Easy to do
    Pantonelli likes this.
  3. gkterry
    gkterry Tele-Meister
    Paris, IL
    I use a straight edge to keep them in line And found the easy way is to place the tuner where you want then give it a rap with my rawhide hammer which marks where the holes need drilled. Just do one at a time while carefully keep them lined up.
  4. el cheapo
    el cheapo Tele-Afflicted
    Southcentral Pa
    Just curious, why do you want locking tuners?
    Greg_L and Doctorx33 like this.
  5. Pantonelli
    Quartz Hill, CA
    Honestly, because I was told they are better.
  6. el cheapo
    Southcentral Pa
    Problems caused by tuners are rare. The great majority of tuning issues are the result of a poorly cut nut. Get your guitar set up properly and IMHO you should be just fine with your stock tuners.
  7. Nick Fanis
    Nick Fanis Friend of Leo's Ad Free Member
    Athens-GREECE
    They aren't.
    Move on please ;)
  8. marcflores
    marcflores Tele-Meister
    San Francisco
    They're mostly good for faster string changing. If they improve tuning stability at all, it might be because of less slippage with winding. But I'd say theain reason for buying locking tuners is for strong changing.
  9. marcflores
    San Francisco
    Apparently, I can't type.
    AAT65, LutherBurger and MatsEriksson like this.
  10. MatsEriksson
    MatsEriksson Tele-Holic
    Sweden
    If you have a Telecaster, the only benefit is of faster string changing, and if you use the staggered ones, you get rid of string trees. But when you just bend strings with playing fingers, the most things happens at the nut.
    If you use a stratocaster with floating trem and are whammying a lot, they do make a lot of sense in tuning stability. It really keeps them in tune better. However...
    If you need a constant maintenance on guitar, in terms of taking off/on/off/on repeatedly to say, change the truss rod at the heel on some guitars, you need to change to new set all of the time. On Klusons with in holes you can get them back again, but if you've cut your strings on a locking tuner right next to the tuner post it's impossible to get them back again through the hole.
    But I think you'll know that. If you are thinking in advance, that you'll have to have them off/on for a repeated number of times I suggest you just wrap them around the post the normal way AND DO NOT LOCK THEM. Until you're set and done and then you take a plier and stretch them out, then lock them, and you have not even half a turn to make before you tune them.
    On a non tremolo guitar it's just a few advantages:
    1. Once tuned up, and locked they DO stay in tune, and you don't need to ever do a touch up. On stage this can be of tremendous advantage. Let the guitar reside for a couple of days, and the brand new strings are still in tune. With normal Klusons the wraps around the posts are showing their flexibility and you still have to readjust because they've slacked in tension after a couple of minutes into while playing a tune..
    2. Faster string changing. Who actually likes changing strings? It's a chore anyone wants to be done as fast as possible with as little struggle as possible and without the help of tools as much as possible. This you can do with locking tuners. No wire cutters at hand?
    Wiggle the excess end of the string a couple of times back and forth with fingers, after 30 seconds it will fall off. And you won't a) get stung by the sharp edges from the string, it's more blunt. b) It won't rip your cloth up inside the gig bag at the headstock department. These days I use this method even if I have wire cutters at hand.
  11. MatsEriksson
    Sweden
    You know that you can press the small "EDIT" icon below on your own posts, and go in and re-type and correct your typos? I do constantly. I can't type either. It can take days, and since I don't review my own posts, I "re-detect" the erros and palmface myself and go in and corrects...
  12. Pantonelli
    Quartz Hill, CA
    Thank you.
  13. CalebAaron666
    CalebAaron666 Tele-Meister
    Portland, Maine
    I have bigsby’s on 3 Gretsch’s and on my tele. Locking tuners aren’t necessarily essential, BUT they sure do make restringing a breeze! I love them!
  14. marcflores
    San Francisco
    Ah. I was typing and using my phone last night so I didn't see that. Now I know!
  15. vanr
    vanr Tele-Afflicted
    AZ
    I have locking tuners on all my guitars but 2 and one of them has the vintage split-top tuners, so no locking necessary. The other guitar will get some locking Hipshot tuners as soon as finances allow.
  16. wrxmania
    wrxmania Tele-Afflicted
    Scotland
    I have Fender USA tuners on my Squier Affinity and they dropped in, but needed new screw holes I am sure. Fitted to this guitar:
  17. wrxmania
    Scotland
    I also fitted Wilkinson locking tuners on this one, which seem good too
    (There are detailed rebuild threads on both these guitars on here )
  18. radarman
    radarman Tele-Meister
    Colorado
    I respectfully disagree with the problem is almost always the nut and others saying it can't be tuners. It could very well be a poorly functioning tuner, especially on a Squier. I have a Squier Pro Tone Strat and the neck twisted so I bought a Classic Vibe neck for it, and a couple of the tuners were not holding tune. Since I was going to have to buy a new set of tuners then why not locking tuners. So I picked up a set of Jim Ho Korean made lockers off of the bay, gold ones and the guitar has held tune rock solid ever since. IMHO the Squier vintage tuners aren't the highest quality tuners out there. I would highly suggest you look at a set of these Hipshot locking tuners that come with a mounting plate and require no drilling on the headstock.
    http://rover.ebay.com/rover/1/711-5...0001&campid=5338148343&icep_item=311657563512
    But if you are like me and don't mind drilling a little and filling a little then the Jin Ho locking tuners are about as good as Schallers..
    http://rover.ebay.com/rover/1/711-5...0001&campid=5338148343&icep_item=292084909213
  19. EspyHop
    EspyHop Tele-Meister
    Dayton, OH
    This.
    The original tuners on my 91 MIM were terrible and I had a lot of tuning issues. I replaced them with Gotohs, which were drop-in replacements, and the tuning problems immediately went away. The tuners were much smoother and more accurate.
    As for locking tuners, I would only recommend them on a Tele if you’re doing a lot of gigging where time is of the essence and need a quick string change.
  20. radarman
    Colorado
    Locking tuners also increase the metal mass on the headstock, and in my case the guitar actually sounds better with better sustain. To each his own.. quick and easy string change can be a blessing even at home.
