So.....you've got Hipshot, Fender, Kluson, and Sperzels. Let us know if you get some, and which ones you got.Looking for locking tuners for this Squire Tele. Any suggestions greatly appreciated.
I've put Fender's own locking tuners on to a Mexican Tele and Strat. Easy to install, no drilling necessary. I don't know if they'd fir on a Bullet but you could check.Looking for locking tuners for this Squire Tele. Any suggestions greatly appreciated.
I tend to agree. Those are fine tuners on that pic in the OP. Unless this guitar has a vibrato bridge, the only benefit will be slightly faster string changes.Why?
Hopefully, you aren't just getting them because the internet said you had to for a Squier.
The Squier Standard series tuners work fine as long as you know how to properly string a guitar, if "tuning stability" is a concern. You might also want to make sure the nut slots are cut right for the gauge string you're using.
If string changing convenience is what you're after, you can get spendy ones or you can get relatively inexpensive ones in the $25 range that work fine.
