little solid state combos and speaker impedance
Greg M
Virginia
I have a little Behringer GM108 amp with a 4 ohm speaker and a Marshall Valvestate MG15CD amp with an 8 ohm speaker. I don't know if the impedance is as big a deal with these as it is with tube amps, so I thought I would ask you guys if it would be okay to hook both speakers to the Behringer at once without damaging the amp. The Marshall amp is junk so I figured I could get a bit more volume using two cabs. Thanks for any advice.
Ed Storer
Seattle WA
I would recommend against doing that. Solid state amps are fine with more impedance, but tend to fry power transistors if the impedance is below minimum.
I don't think the 8 Ohm speaker would give you any more volume since the 4 Ohm speaker would dtaw 2/3 of the current.
PhredE
Suburban PDX, OR
A couple of random (hopefully related) suggestions and points I can throw out..
1. Of course, it IS possible, but is such thing advisable and/or without potential problems or side effects?? (answer: yes -- it could be problematic, depending).
2. a. Wiring an 8ohm and 4 ohm speaker in series yields: 12ohm load to amp
b. Wiring an 8ohm and 4ohm speaker in parallel yields: 2.7ohm load to amp
Almost no audio amps --guitar or otherwise-- are designed to support loads that small (4 is the usual practical minimum)
3. A greater load to amp will reduce power output, so a 12ohm load will lower the amp's output power with the greater load (compared to the stock 4ohm speaker). So, you may gain in having a second driver putting out the signal, but will give some that gain back by 'taxing' the amp's output somewhat. "It's a mixed bag", and not easy to predict actual output quantity/quality.
4. Perhaps even a greater consideration beyond the electronics-related stuff, is are you ok with connecting (soldering, adding a jack, etc) the speaker via serial or parallel connection?
It's possible to trash your amp by getting the basic wiring 'wrong' -- so it's fairly important to get the wiring stuff correct in order to make it all work.
5. I went on a cursory search for specs on that 8" Bugera speaker and couldn't come up with very much. A simple speaker swap may give more output if you can find a decent sounding but more efficient replacement. Without knowing the sensitivity rating of the existing speaker it's hard to know if a replacement will give much of a output boost.
Speaker:
Bugera 8" 20W, 4ohm.
Greg M
Virginia
Thanks for the responses guys. It sounds like it's not really worth attempting. I may be asking more from this little amp than it's fair to expect.
rdjones
Music City, TN
Does the amp have an extension speaker output jack ?
Is there anything marked on the rear panel or written in the owner's manual that might provide specific information ?
