Lil Bumble-B (2-channel micro)
Discussion in 'Shock Brother's DIY Amps' started by Lynxtrap, Jun 2, 2021.
  1. Lynxtrap
    Lynxtrap Tele-Afflicted
    EU
    With all these great micro builds going on here, I couldn't resist it anymore :)
    Like the rest of us I have of course been looking at the designs by @robrob
    I began to plan a "high power" Twin, essentially the Bassman but with two pairs of output tubes, with half the 12AY7 as a switchable extra gain stage.
    Then I started thinking a 4 triode output stage kind of defeats the purpose of a "micro", and started rethinking it.
    I ended up with 5F6A/RobRob's circuit as the basic clean foundation, instead adding an overdrive channel that is sort of inspired by a Dumble ODS and also a design by Kevin O'Connor.
    The overdrive channel will most likely be tweaked when I get sound out of it, so this is more like a starting point. I put a switchable Framus mid control in there as well, I liked it in a previous build.
    I had already ordered a pre-drilled Marshall 18W chassis with five tubes. Haven't got it yet, I guess it might be a bit of a challenge to find room for the circuit, knobs and switches.
    The pre PI master and the presence control are left out for this reason.
    It's kind of Dumble, Bassman and it is little, so...a Lil' Bumble-B :rolleyes:
    Anyway, here is the first draft for it. Grateful for any input, opinions, suggestions etc!
    JohnnyCrash, King Fan and sds1 like this.
  2. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    Looks fun! Seems like it will work but arm yourself with the parts and be prepared to balance out the various stages post-build...
    D3 and D4 are misoriented.
    The bleeder could be as small as 220K if you wanted a 4.5X faster bleed.
    JohnnyCrash and Lynxtrap like this.
  3. Lynxtrap
    EU
    Thanks, yes I think there might be a bit much gain in the drive channel, but had to start somewhere and tweak when I hear how it sounds and works.
    I see the error with the diodes now, thanks for pointing it out. I was kind of in a hurry to get it done, and drawing schematics on a computer is not my favourite part of amp building :oops: But they sure turn out easier to reed than hand drawn, and as Rob is kind enough to provide the DYIC file on his website I thought I'd go for it. I had to use a battery symbol for the electrolytics as I couldn't find the right one in the software :lol:
    sds1 likes this.
  4. Lynxtrap
    EU
    By the way, has anyone tried a bypass cap on the cathode resistor for the output tubes in a micro?
    JohnnyCrash likes this.
  5. Asmith
    Asmith Friend of Leo's
    East Yorkshire, England
    I have but I didn't try without so I have no idea what differences there would be.
    Also the high gain mode will sound like a load of bees in a can. 4 gain stages even when most of them at 12ay7s is a lot.
  6. Lynxtrap
    EU
    What value did you use for the cap?
    What makes you think that? IME you can have as many gainstages as you want as long as they are well balanced and attenuated at the right places.
    robrob and sds1 like this.
  7. robrob
    United States
    The DIYLC capacitor has a check box for polarity which turns it into an electrolytic.
    Lynxtrap and sds1 like this.
  8. JohnnyCrash
    JohnnyCrash Doctor of Teleocity
    Fullerton, CA
    I’m un-paralleling the 12AY7 and instead adding a JCM800 cascade switch on mine (Gain DPDT pull switch).
    I’ve had success cascading a 12AY7 in my full-size tweed Pro/Super head.
    Watching this thread!
    robrob and Lynxtrap like this.
  9. King Fan
    Salt Lake City
    Aha. Gotta look deeper in the 'schematic symbols' goody bag.... "polarized". Hadn't noticed that. Thank you, Rob.
  10. Lynxtrap
    EU
    I got around to doing a layout.
    I have never built an amp with this kind of board before, with the components in a row. I ordered a board with pre-installed turrets, 30 on each side. And I managed to fit almost all components on it. On paper at least ;)
    The chassis is not this deep in reality. The tube sockets sit closer to the board, and the PT wires will come up underneath the distribution board.
  11. Lynxtrap
    EU
    Some small corrections and updates. The Clean/OD switch was not wired correctly, for one. Switches always mess with my brain...
  12. mountainhick
    mountainhick TDPRI Member
    Rocky Mountains
    I'm a little confused about the schematic, I understand the circuit as I see it, but I don't understand calling both the input triode and the gain section, two tubes, for a total of three triodes V1.
    Input V1 "AB Parallel", and V1 gain circuit triodes are two different tubes, no?
    When engaged, the gain stage is in series with the input tube. What is the V1 "AB parallel" about?
  13. Lynxtrap
    EU
    Two V1 is a typo, and I hadn't even noticed that I forgot to draw the second parallel half of the actual V1! Thanks for pointing it out!
    I decided to have both triodes of the first tube in parallel like in Robrob's schematic. Because we can't have an unused triode, right? :D
    On the serious side, parallel triodes has advantages while not really adding gain.
    mountainhick likes this.
  14. mountainhick
    Rocky Mountains
    OK, thanks, I'm not :confused: after all.
    What are these benefits of parallel triodes at unity gain? I could make a somewhat educated guess regarding current and tube longevity, but I'd just be guessing.
    Lynxtrap likes this.
  15. Lynxtrap
    EU
    Actually gain migh be a little higher, but mu is the same as one triode. Since it is connected in parallel, there will be twice the current capability, capacitance, power rating and transconductance. Plate resistance is halved.
    The performance can of course be altered with component choises, and almost always is, like half the cathode resistor value (820R) in this case and in Robrob's circuit half the plate resistor value (47K).
    It can smooth out a 12AX7 a bit, since the performance of the gain stage will be more similar to a lower mu tube, but still with the gain of a 12AX7 triode.
    The 12AY7 has lower mu, so it remains to see how that tube works in this configuration. I guess it works fine since Robrob uses it in the micros, and many have built that circuit.
    Matchless is one maker who is fond of parallel triodes, they can be found in many of their amps and often run quite hot.
    I basically thought that the spare triode might as well be put to use.
    I will correct the schematic when I have the time.
