Lifeless Mexi-Strat
Discussion in 'Stratocaster Discussion Forum' started by WrayGun, Oct 26, 2013.
  1. chesire
    chesire Tele-Afflicted Silver Supporter
    The Ol' Pueblo
    It is in most cases although some will require a US whammy.
    I did the Fender MIM Big Block upgrade. It was a legitimate Fender part listed on eBay for about $22. To give you an idea it weighs 2x what the alloy stock one weighed. Also, a magnet wouldn't stick to the stock block but they cling to the pure steel one. I'll see if I can find a part number.
  2. String Tree
    String Tree Doctor of Teleocity
    Up North
    If it doesn't do what you want, make another trade.
  3. Glen Smith
    Glen Smith RIP
    I bought a brass block from GFS and the hole for the trem arm is at an angle causing the arm to be quite a distance from the guitar body. I emailed them about it and they said that is how they are made. Anyone else run into this?
  4. Warren Pederson
    Warren Pederson Tele-Afflicted Silver Supporter
    Kelowna B.C., Canada
    that thing can't be threaded right. Right?
  5. Glen Smith
    Glen Smith RIP
    That is what I told them but they insist it is threaded at an angle on purpose. I think I will SuperGlue a brass screw in there then drill and tap a straight hole.
  6. PJ55
    PJ55 Poster Extraordinaire
    Philadelphia, PA
    I usually buy both a vintage bridgeplate (the chrome plate) and the steel block from AllParts. If you have one of the Classic Series reissues, these will work and covert your bridge to a US-Spec vintage bridge. If you have the Standard Series Guitar, it gets tougher to replace just the block. It's easier to replace the bridge sometimes. But, there are steel blocks out there that should work. Beware of descriptions like "Big Block" - size isn't the issue, but material is. Big Block won't get it done. A steel block will. But, Fender makes all kinds of steel block bridges for both US and import Strat bridge spacing. Gotoh and Wilkinson do also. There is a steel block bridge assembly or block out there for your guitar.
    It's getting the right one. I believe the Mex Std uses 2 1/8" string spacing and the US vintage string spacing is 2 3/32." Doesn't sound like a lot of difference, but the two bridges (or blocks) are not interchangeable.
  7. Octave Doctor
    Octave Doctor Tele-Afflicted
    Morgantown, WV.
    Just put the trem arm in a sturdy vise and bend it to fit. Tape up the threads if you're that worried about it. Hendrix used to re-bend his bars to get the right angle.
  8. sparkletele123
    sparkletele123 Tele-Meister
    London, UK
    Put some Seymour Duncan's in it, that will make a huge difference.
  9. Ron C
    Ron C Tele-Meister
    Long Island, New York
    2001 MIMs like the OP's had alnico pups. The change to ceramic came sometime later (maybe 2006?)
    Bone stock, this guitar should sound pretty darn nice. The OPs description of it being lifeless, and not much difference in sound with the various pickup positions makes me wonder whether something got messed up with the electronics from a botched mod.
  10. Luthier Atlanta
    Luthier Atlanta Tele-Afflicted
    Atlanta
    Get a loaded pick guard and don't look back...
  11. Glen Smith
    Glen Smith RIP
    After viewing the photos of a trem block posted by Scooby Snax and Kevin B I must retract my negative comments about the brass block I got from GFS. It appears that it is made just like other brands.
  12. PJ55
    Philadelphia, PA
    Wilkinson offers a Steel Block Vintage bridge for 2 1/8" Mex-Std string spacing. And, these aren't overpriced - usually $35-50 depending on where you buy it. I've used one and it was a good upgrade bridge for a Mex Std or Squier. Pretty sure Fender also has an aftermarket version of this unit, that Angela stocks.
    (www.angela.com)
  13. PJ55
    Philadelphia, PA
    Finally, there is one other option not yet mentioned that's by far the best solution to the bridge and bridgeblock dilemma. And that is, to go to your luthier and ask him/her to dowel and redrill your body for the US-Spec Vintage Trem unit. If you have a Mex-Std. and you like the color and neck, putting the US vintage bridge on your body will make your Strat feel and sound like a Strat should. I did this with an old Made-in-Mex body I found at a guitar show that I wanted to build-out since it was a nice, aged Oly-White color that I'd been looking for. I think my luthier charged me $50 to dowell and redrill for a US vintage bridge. And, this project turned out to be the nicest Strat I have. Or have ever owned. It now has a classic reissue maple neck, US pickups and pots and a US vintage tremolo bridge. Probably the easiest way to skin the import bridge dilemma, once and for all. Just a fabulous guitar. So, that $50 was money well spent.
  14. charlie chitlin
    Spring City, Pa
    I think I have that guitar now.
    I LOVE the pickups!
    That guitar is in heavy gig rotation.
    Whenever people talk smack about Mexican ceramics, I don't know what they're talking about...but I also thought these were representative of all of them.
    This guitar also has these meaty cast saddles...not like the stamped ones.
    I'm putting together another MIM Strat now...I'll have to A/B the tones.
  15. JayFreddy
    JayFreddy Poster Extraordinaire
    Dallas TX USA
    I have one of those and mine is NOT at that angle...
  16. marktwang
    marktwang TDPRI Member
    calgary ab
    I got one a few years ago,and some of the frets were not glued in so it felt dead.My guitar guy fixed that and it was much better.
  17. PJ55
    Philadelphia, PA
    Obsessed....if you're OK with the stock Mex-Std. hardware, I'd skip an upgrade. It's more driven by what your expectations are. I played my first Strats in the 60s, when there were only steel blocks and that's the tone I both remember and expect from a Strat. And, it can't be obtained with the die-cast parts that the lower-end guitars use. Sure, if you're after better tone, you can change a tone block, a bridge or drill your guitar for the US vintage hardware. It just depends on what you're after really. If you look at the amount of aftermarket parts, especially high-end ones, like Callaham and Glendale, a lot of folks want to maximize the tone of their Fender guitars. And, often the factory hardware is pretty average, or sub-par in the case of the value models. This is more than likely where the upgrade opportunities are.
  18. Mike Eskimo
    Mike Eskimo Doctor of Teleocity Ad Free Member
    Detroit
    Charlie !
    I want that damn guitar back right now ! :lol:
    That would be a good gigging guitar - could probably do everything.
  19. charlie chitlin
    Spring City, Pa
    Yup...it's a good gigger!
