mountainhick
The other thread got sidetracked with the naming thing etc, I am calling it Bobcat.
Let's bring it back to tech talk.
I've been playing with it and it needs work. I expected as much, a few things are experimental. Basically, it has a good clean sound and a little useful range with breakup and distortion. But...
First off the circuit:
I don't know what's up with DIY creator, I can't even edit this further. It just totally locks up. There are a few minor inconsistancies and the power section isn't drawn. Has SS bridge rectifier and filament supply has artificial elevated CT with 100 ohm resistors.
The input has two jacks, typical Fender style Hi/Low with a single 1M grid leak and two 68K, for 68 K or 34 K in parallel.
Power transformer is ANTEK toroid 05T200
Output Transformer is EDCOR XPP-10-8-10 10 Watt 10K primary, 8 ohm secondary.
Filaments 3.14 and 3.16
First time using Robrob's bias calulator, does this look all right and good? If this calculator is for one tube, this is very cold. If it is for 2 tubes, would be 9.2 watt, 77%, which looks good. Which is right?
6AQ5 specs:
6AQ5 specs:
