gb Custom Shop
FWIW, I've become a proponent of machining the neck taper before facets & profile carving. This offers a consistent taper along the neck, without bumps/divots. It is more difficult and time consuming (for me at least) to get a perfect taper with hand tools
What I do is rip some tapered stock on the table saw to act as an angled shim. Say I want a 0.10" taper from the 1st to 12th, the stock I'll rip would then have that difference of a thickness across ~12-13". I'll then place that shim underneath the neck (fretboard side). Then with the router (with a base that I use just for this), I'll set the depth I want off at the first fret. Say I want my first fret thickness to be 0.85", and my neck is 1" thick to begin with, I'll then set my router depth to be 0.15". The shim underneath takes care of the rest, and I should then end up with 0.95" thickness at around the 12th fret. After a few minutes, the taper is perfect and I can move on to drawing my facet lines.
I'll explain my set up for this, with pictures, in my current build thread in a couple weeks time. But I got the idea from Steve at Maximum Guitar Works, although he uses a safe-t planer in the drill press instead - you can find his video here, which is an excellent video resource on neck carving:
