Let's call it a "μ-GA-9T" or "μ-Vibro5E1" - parallel SE design questions
Discussion in 'Shock Brother's DIY Amps' started by gigante, Feb 13, 2021.
  1. gigante
    gigante Tele-Meister
    Kansas City
    OH NO! I mean "micro vibro 5c1"!
    After building a little 6SJ7 into 6AK6 SE amp last year, I want to do it again. Last one I just put together some circuits I found online, but I am trying to be a little more deliberate this time. I'm mostly happy with the previous amp, but want to make some changes.
    This time I want to do parallel SE output. Using the datasheet suggestions for the 6AK6, each wants to see 10kohms, which means the two together should want 5kohm, correct? Probably the hammond 125ASE.
    I may put individual cathode resistors to allow me to pull (or switch off) a tube for half power (and double impedance).
    I also want to add tremolo. I was looking at the Kalamazoo Model 2 for a one-triode trem. Could I use the other half of the 12ax7as a gain stage? Would there be noise issues sharing a gain stage with the trem in a single tube? The triode gain would probably be before the pentode stage, because I want to get most of the preamp character out of the pentode. The Gibson GA-8T uses parallel output and has trem, but I don't know if I like how it's done. Or I'll just do the two triode
    PT will probably be the antek toroidal into at bridge rectifier.
    Am I making any bad choices here?
  2. NTC
    NTC Tele-Holic
    A 5E11 and 5F11 Vibrolux shares the oscillator with the preamp. No issues.
    gigante likes this.
  3. gigante
    Kansas City
    Thanks, good to know.
  4. RollingBender
    RollingBender Tele-Afflicted
    SW Minnesota
    I recently built a single channel version of a blackface Deluxe but I subbed in a Princeton style 1/2 tube tremolo and a one tube reverb to keep the tube count down. The other half of the tremolo tube is being used as the last gain stage before the PI. I have no noise issues with this setup.
  5. gigante
    Kansas City
    Thanks for the additional confirmation.
    I read this somewhere, but the schematic I see looks to be PP. So it looks more like the princeton. GA-8 is parallel SE but GA-8T is PP. At least in the schematics I can find. I know Gibson liked to change things within a particular model?
  6. gigante
    Kansas City
    Per my other thread, I'll be going with the datasheet class A operating conditions.
    Here's my planned loadline: Load 10k per tube, 180V on the plates, 14mA per tube. Grid Bias will be -10.33V.
    As I understand Keuhnel, the grid can swing from -22.66 to 0V, and therefore my headroom will be 10.33V peak (17.3dBV). This would be clean(-ish), correct? So I want master volume control at 50% to give 10.33V peak, or close to it. I think.
    It should be obvious I am trying to learn all this, so don't be afraid to tell me I'm doing it wrong.
  7. 2L man
    2L man Tele-Meister
    Finland
    Looks good but perhaps you should use other Giuseppes calculator (Universal) where you can play with "headroom" and then you see distortions
    Grid can become positive and on datasheet they are on AB2 tables. Grid drive to zero volts and it is AB1. On Universal Loadline Calculator you get both powers. I have noticed that Screen voltage effects how "high" g1 as 0 rise.
  8. gigante
    Kansas City
    I'm using the universal calculator. When I put in 'headroom' values, I get the green area under the line, but I don't really understand how to use that info to make decisions.
    Headroom set to 100V
    at max g1:1.21
    at g1=0:1.21
    at class A/A2:0.98
    at headroom:0.50
    2nd:4.64 3rd:2.01 4th:0.30 THD:5.07
    Headroom set to 155V
    at headroom:1.20
    2nd:4.30 3rd:11.05 4th:2.59 THD:12.13
    Headroom set too high like 225V
    at headroom:2.53
    2nd:9.38 3rd:19.43 4th:1.96 THD:21.67
    Obviously as the output stage gets pushed harder, distortion increases, but I don't know what those distortion levels sound like.
