Let's build a 5f2a Princeton!
Discussion in 'Shock Brother's DIY Amps' started by corliss1, Aug 28, 2020.
  1. corliss1
    Lansing, MI
    In one of the many recent threads about Princetons I posted a picture of one of my recent builds, a point-to-point 5f2a built as a head in a small Hammond enclosure. One of my regular customers tried it out while picking up another repair and asked me to build another, so I figured I'd post some pictures of that process.
    Since I'm apparently doing multiple of these builds, let's make a routing template for the power transformer.
    Close enough. It'll get sanded and straightened out a bit more.
    Press the transformer down into the wood to mark the screw holes:
    Seems to fit well:
    Mark a center line on the chassis:
    "Let's start at the very beginning..."
    See how long a resistor reaches and mark that point:
    Drill a slightly awkward hole:
    Use a punch to make it much less awkward. Super fun that the tube socket mounting hole ended up being right in the middle of that "o":
    Scene from the inside:
    scook, monkeybanana, dan40 and 7 others like this.
  2. WalthamMoosical
    WalthamMoosical Tele-Holic Ad Free Member
    Vermont
    Great, let's! I'll just sit here and watch!
    Timmay, D'tar and corliss1 like this.
  3. corliss1
    Lansing, MI
    Let's make some baby starter holes for the fuse holder, switch, and pilot light:
    Those holes grow up so fast!
    Let's countersink that template so we have a way to attach it:
    Router bit with guide:
    And there we go:
    Routing aluminum always makes the coolest little pieces:
    Looks good - the rough edges are the protective layer of film on the chassis. It'll get deburred later on anyway:
    Fits:
    Laying out the Volume and Tone controls - gotta make sure there's enough room for the Fender knobs, which is what the customer requested:
    Holes for pots:
  4. corliss1
    Lansing, MI
    So I have a bunch of these speaker output plates I designed for my other (usually full-sized) amp builds, but this chassis is a bit thinner. I want to use it since it'll give it a more pro look on the rear panel:
    I cut some 1x2 in half and routed a channel in it:
    Used the second piece to hold everything together. More drilling and countersinking:
    Routed off the edges. Once again, the roughness is just the protective film. It should be about 1/8" or so shorter than the chassis now:
  5. goonie
    goonie Friend of Leo's
    Subscribed!
  6. Paul-T
    Paul-T Tele-Meister
    London
    Looking good!
    I've only just realised how easy it is to route aluminium. What router bit do you use?
  7. corliss1
    Lansing, MI
    Anything. Literally any decent bit you use on wood is fine.
  8. WalthamMoosical
    Vermont
    What about that plastic thingy that hides the sharp inside edges of the hole in the aluminum? Is that off the shelf, or did you fashion it, or re-purpose something?
    This is going to be an interesting and instructive show.
  9. screefer
    screefer Tele-Holic
    kildonan
    subbed!
    I've been thinking about attempting this since you posted it back on Jul. 10.
    Very instructive.
    corliss1 likes this.
  10. corliss1
    Lansing, MI
    Help me out here - which photo are you seeing this?
  11. WalthamMoosical
    Vermont
    In post #3 underneath where you wrote "Fits"
    But looking at it again, I guess that's just part of the transformer body (itself being held in by four bolts). I thought it was a deliberately-installed softer edge that wouldn't fray wires going through the rectangular opening (such as for a grommet for a power cord).
  12. corliss1
    Lansing, MI
    Yup - nothing else in that photo except the PT and chassis.
  13. Liam77
    Liam77 TDPRI Member
    Europe
    Nice. I'm impressed how you use teh wooden template to route the chassis for the transformer. I never thought about using a router for metal work.
  14. corliss1
    Lansing, MI
    @Liam77 - as long as it's aluminum. If you try and do that with steel, it's going to end badly.
  15. King Fan
    Salt Lake City
    Niiiiice.
    Did you say where you got the chassis? Your shop, or?? Looks great. What gauge alu?
    Plus I really like that DPST switch, and the way you're custom-locating stuff to fit PTP. I'm gonna enjoy this.
  16. screefer
    screefer Tele-Holic
    kildonan
    Regarding your DPST switch, are those threaded lugs? Do I assume you will solder to those lugs? Would threaded lugs require more/quicker heat?
    Will you be switching both hot and common AC in?
  17. andrewRneumann
    andrewRneumann Tele-Holic
    Cincinnati, OH, USA
    You have got to wear eye protection though. My experience cutting aluminum with anything is that it goes everywhere, including in your face.
    D'tar, Nickfl and Timmay like this.
  18. corliss1
    Lansing, MI
    Chassis is this guy, with a matching cover plate: https://www.amplifiedparts.com/products/chassis-box-hammond-aluminum-10-x-6-x-2
    I don't know if that's the *exact* switch I'm gonna use, they all have the same bushing diameter though.
    ^^^This
  19. Timmay
    Timmay Tele-Meister
    Ohio
    Subscribed. I've been thinking of attempting a 5f1 this coming winter.
  20. D'tar
    D'tar Friend of Leo's
    WNY
    While we're on the subject...
    Aluminum dust is potentially explosive. Just saying.
    That said,
    I've worked a lot with aluminum and never blew anything up.
    andrewRneumann and King Fan like this.
